Armand,
There is a technical book called
Designing With Geosynthetics 4th Edition by Robert M. Koerner. Chapter two within this book is titled Designing with Geotextiles and it is a good reference for this type of question. Section 2.2.3 Filtration specifically and then the subheading Soil Retention on page 85 will lead you best to a solution. Though there are many factors that will effect the rate of sediment transport in lined channels (as stated in previous replies); some natural (i.e. river flow rate) and some unnatural. For the unnatural factors many of them are a result of the initial geotextile chosen and the void space associated with that specific filter fabric. If the void spaces in the geotextile are too large
soil piping can be caused which will accelerate the process of the soil structure beneath the riprap collapsing. To prevent this, it is the coarser soil fraction that must be intentionally retained and that is the targeted soil size in the design process. The coarser-sized particles eventually block the finer-sized particles and build up a stable upstream soil structure.
To answer your question, Yes absolutely the geotextile will prevent material from being eroded away. Also for design purposes, it is recommended that 4-6 inches of about three-quarter inch stone be placed on top of the geotextile prior to the installation of the riprap. This will provide a solid base for the riprap, further prevent erosion, protect the geotextile from damage, and provide stability.
I am not aware of any studies between lined vs unlined channels and the rate of sediment transport.
Best,
Darrell
Darrell Kennedy EIT, A.M.ASCE
Environmental Engineer-in-Training, Remediation, Environment
AECOM
Boston MA
