Expand all | Collapse all
Climate Change
  Thread closed by the administrator, not accepting new replies.
  • 1.  Climate Change
    Posted 03-01-2017 10:57 AM
    No replies, thread closed.
    The geological record shows lots of effects of climate change.  In fact, the world has been warming since the end of the last ice age, right?  Is the weather variability we see today the same or different?
    Jeffrey Keaton Ph.D., P.E., D.GE, P.G., ENV SP, F.ASCE
    Principal Engineering Geologist
    Amec Foster Wheeler
    Los Angeles CA
  • 2.  RE: Climate Change
    Posted 03-01-2017 03:35 PM
    Well, sea level has been rising since the last ice age anyway.  There was a time since the last ice age called the Medieval Warm Period when mankind flourished - temps were warmer than now, the Sahara was green, and the Vikings settled Greenland.  Since then temperatures were falling at about the same rate that they fell at the end of the Eemian interglacial 100 kya - the interglacial before the current one, the Holocene.  There is a theory that the industrial revolution saved us from that continued temperature fall.  There is so much convolution in climate "history" that ground based measurements ... are not robust.  There are little fingers adjusting the "data"...  Not that all climate scientists are on the take, but it certainly appears to get more funding if it's bad news.  To say that none of them fiddle with the ground based observations is a little naive.
    The local record here in Albuquerque has moved three times over the last few decades and is now near the airport, where continued expansion of that facility means a lot of asphalt pavement near the thermometer.  No wonder the temperature record there is going up.
    The only factual information about temperatures is from satellite data -  University of Alabama at Huntsville has that record.  Google uah msu tlt and you can get the monthly record.  It's much less alarming than what the "news" channels put out - but then again their job is to entrap viewers for the upcoming commercials.  The UAH data is broken out by latitude as well as by land vs. ocean.  You will notice the trend of the increase is greater the further north one goes, the theory there is that black carbon deposition, deforestation, overuse of arable lands, etc. are more concentrated in the north.  CO2 is pretty well mixed though.
    Human nature is to remember the good times, so current bad weather sticks out - also everybody has a camera now so documentation is far more extensive.
    I'm not saying there's no global warming, but it appears more and more that CO2 may not play a major part in it.  Plus, it may have saved us from dropping down into the next ice age.
    Stephen Hemphill P.E., M.ASCE
    Semi-Retired
    Rio Rancho NM
  • 3.  RE: Climate Change
    Posted 03-02-2017 09:40 AM
    I am sorry to say that Mr. Hemphill's comments are somewhat misleading. There are many, many sources where one can find see the incredible scientific consensus that climate change is real (as is sea level rise) and that with a very high degree of likelihood - please see e.g. the statement by the American Geophysical Union http://sciencepolicy.agu.org/files/2013/07/AGU-Climate-Change-Position-Statement_August-2013.pdf . The issue of a slow down in warming has been soundly de-bunked - see https://www.nytimes.com/2017/02/07/science/2015-climate-study-data.html. If you can access it, you may want to read the Science article that the NYT references. As an aside CO2 isn't the only greenhouse gas - methane is also problematic for example. One thing to beware re the internet - if one searches on "global warming data" (for example), mostly what comes up are the "alternative facts" being peddled by Breitbart et al., so please look for articles in mainstream media with substantial longstanding reputations to protect, or even better, scientific societies like AGU.
    I like the fact that ASCE is taking a more proactive role and trying to come up with means of adaptation to climate change. Nonetheless, in terms of things we Civil Engineers will be dealing with:  I was recently on an NRC committee reviewing the Everglades, and one of the most frightening aspects was thinking about what sea level rise, another aspect of climate change, would mean for South Florida over the likely timescale of the restoration efforts. For example, consider that the official elevation of Miami is 6ft - increased flooding and possible damage to their water supply due to seawater intrusion are likely effects of sea level rise - what means will we find to adapt to these changes? Here in California, as documented by Dan Cayan and Mike Dettinger at Scripps, we are already seeing effects of warming as more and more often in the past couple decades our precipitation falls as rain and not snow - this is a problem because our water infrastructure is designed to take advantage of storage of water as snow on land until it is needed in summer for irrigation. Thus State of California water engineers are trying to come up with plans for how to adapt to the changed hydrology, something that is proving difficult and may require major new investments in facilities etc..
    Stephen Monismith
    Professor of Civil and Environmental Engineering
    Stanford Univ
    Stanford CA
  • 4.  RE: Climate Change
    Posted 03-02-2017 01:47 PM
    Civil Engineering is an ancient, honorable profession.  When the major uncertainties are resolved, which side do we want to be on?  History will show how we approached this situation.  Humanity is in for a tough row to hoe in the near future, but some of the important things are overpopulation, water supply, and destruction of arable land, not a few millimeters of sea level rise.
    One thing I submit to the group is that if all the money given lining the pockets of those (pretending to be?) alarmists profiting on said alarmism had gone into research on alternative energy instead, solar etc. efficiency would be much further along than it is now, and therefore CO2 levels would be lower than they are now.  How much lower and what would be the effect?  There are way too many uncertainties to know.  Read the last two pages of this IPCC report.  That is the "Technical Summary" written by scientists, and is different from the "Summary for Policymakers"  written by politicians.  Huge difference.
    One needs to remember that further funding depends on finding "climate change" is probably going to be disastrous.  The round robin of "peer review" being published in the gray literature like Science, Nature, etc. is not necessarily, bringing robust findings to light.  Professor Monismith, from Stanford reminds me of another professor from Stanford, Stephen Schneider, who said about climate change: "we have to offer up scary scenarios, make simplified, dramatic statements, and make little mention of any doubts we might have."
    Speaking of misleading: There is a huge difference between agreeing that humans are influencing climate, and "CO2 is an evil monster and must be suppressed."  Virtually all scientists agree with the former, not so many the latter.
    For a comprehensive analysis, watch this video from Stephen Corbett on how The Environmental Movement Has Been Hijacked.
    Semi-Retired
    Rio Rancho NM
  • 5.  RE: Climate Change
    Posted 03-04-2017 05:38 PM
    It is very interesting to follow the discussions on climate change – the compelling arguments presented by both Stephen Hemphill and Stephen Monismith. As one core of some disagreements lies the uncertainty associated with the observed data reduction and future projection. The process of data reduction and correlation by central fitting is accomplished by overlooking some variabilities, which could have the flavor to obscure important information. Such an obscurity has serious consequences because humans and many other living creatures have a very narrow threshold of tolerance within which they can live and function. For humans, the threshold with respect to the consequences of Sea Level Rise have become even narrower because we have ventured into the domain of sea by redefining shoreline with waterfront living, industrialization and recreation.
    The problem with the future projection is that the process relies on the capability of a numerical model – which by definition is a soft tool. Despite all the contemporaneous sophistication, the predictability of a soft tool is by no means certain.
    The quoted forceful statement of Prof. Schneider seems to have aimed at decision makers who are often reluctant to act or react to issues like climate change. One should note that during the past few decades tons of literature have been generated by many different quarters – both national and international – and all tend to agree that climate change is real and happening in front of our very eyes. But there should be no illusion that all the conclusions and projections are likely to be correct to the details one would expect.
    The question: to what extent the happenings have been and are being caused by Natural causes and/or by human activities would not stop bothering us – despite the fact that many would tend to incline toward the latter. More on some of the issues on the Science and Consequences of, and Adaptation to Sea Level Rise can be found in two pieces posted in my website: http://widecanvas.weebly.com
    Consultant - Coastal, Port and Marine Engineering
    Vancouver, Canada
  • 6.  RE: Climate Change
    Posted 03-07-2017 12:04 PM
    "The only factual information about temperatures is from satellite data."  This is the most glaring of the many falsehoods in these posts.
    And yes, the IPCC report was influenced politically including from the likes of Russia and Saudi Arabia.  This made the conclusions more CONSERVATIVE (i.e. watered down). .
    The folks who actually study the issue are in consensus.  Human-caused climate change is occurring.
    It is not surprising to see these familiar talking points put out by deniers in public forums, but disturbing to see in forums among professionals in a technical discipline who one would expect to know better about where to get credible information.
    Kyle Thomas P.E., M.ASCE
    Natural Systems Engineering
    Syracuse NY
    (315) 425-9347
  • 7.  RE: Climate Change
    Posted 03-08-2017 11:22 AM
    I just joined ASCE last week and the first email I get in my inbox is loaded climate change denial rhetoric.   We are a technical profession and it is our ethical duty to abide by science, not to bend facts to say something we or others may want us to believe.  Please consider your ethics in light of the consensus of the overwhelming majority of scientists.  I expected more from the members of this organization.
    Sam Diaz, PE
  • 8.  RE: Climate Change
    Posted 03-09-2017 10:16 AM
    I am truly offended by the contention that people that disagree with "conventional wisdom" are acting in an unethical way.  Sam is implying that the "climate change deniers" are unethical.  I am a believer that climate change has been accelerated by anthropogenic activities but I would never accuse those that disagree with me of unethical behavior.  Remember, Copernicus went against conventional wisdom and accused of heresy as a result.  That is worse than being called unethical!
    David Williams Ph.D., P.E., D.WRE, F.EWRI, F.ASCE, Life Member
    David T. Williams and Assoc.
    Commerce City CO
  • 9.  RE: Climate Change
    Posted 03-09-2017 01:19 PM
    I can be persuaded either way on this topic, but to silence skeptics in the name of consensus, now that is truly dangerous territory.
    What is science without skepticism? What is there left to discover if all are forced to agree?
    Brandon Billing P.E., M.ASCE
    Water Resources Engineer
    Coeur D Alene ID
  • 10.  RE: Climate Change
    Posted 03-10-2017 12:40 PM
    As a newcomer, I wrote a post that broke a couple rules of etiquette by stating my opinions in a way that challenged or attacked others.  I apologize to all offended parties. I am  fairly sensitive to this issue and I responded too quickly and emotionally.
    From my perspective, conventional wisdom is what's being challenged by the scientists who study anthropogenic contribution to climate change.  There has been a lot of study over many years that indicates we are part of the problem.  As a result of this investigation (kinda like what Copernicus was doing) 97% of scientists support this view. This has been the case for several years and there is still a lot of reluctance to agree with science.  So I guess I see it the other way around.
    Sam Diaz P.E., M.ASCE
    Nevada City CA
  • 11.  RE: Climate Change
    Posted 03-10-2017 10:45 AM
    Where the disagreement in this thread veers into the unethical for me is that, as licensed engineers we are obligated to limit our professional practice to our individual areas of expertise, and must therefore rely on the scientific community and the balance of consensus in that realm to properly perform our work. I must design coastal systems with the assumption that sea level will rise, I must design stormwater systems recognizing that precipitation dynamics are not stationary, and others should design air treatment systems to conform with permits that reduce CO2 discharges because the scientific consensus is that this is a good idea.
    Science demands constant, healthy skepticism. If you are a scientist in that community please continue to challenge consensus, but recognize that such a challenge always has and always will demand greater substantiation, and that simply highlighting uncertainty and therefore dismissing an entire concept out of hand is not good scientific practice.
    As a private citizen you are free to believe the earth is flat, that the moon landing was a hoax, and that the earth is only 6,000 years old. But here on this post, in your role as a professional engineer, be careful veering outside your area of expertise.
    Timothy Groninger P.E., M.ASCE
    White Plains NY
  • 12.  RE: Climate Change
    Posted 03-15-2017 11:25 AM
    I agree. We have a professional obligation to take all relevant information into account in designing a project. We can measure change in sea level, both rise and fall, we are beginning to discover that the hydrologic record in not necessarily stationary.  Civil engineering is a risk averse, profession, life safety is paramount, safer is better.
    Ralph LaMoglia P.E., M.ASCE
    Civil Engineer
    Wantagh NY
    (516) 221-0636
  • 13.  RE: Climate Change
    Posted 03-02-2017 09:38 AM
    Dr. Keaton,
    Regardless of the degree to which climate change is driven by anthropogenic impacts versus natural celestial periods, the loss of land based ice (Greenland and Antarctica) is quite concerning. I have not done extensive reading of IPCC reports but how serious doubts in how feedback loops are modeled tending toward over-estimating climatic changes. However, the sea level rise projections are likely way off from the potential reality. For example, the loss of land base ice does occur as discrete 'chunks' in addition to continuous melting. Some of these discrete losses may cause substantial 'jumps' in sea level that may overwhelm the pretty, continuous curves in the IPCC/ Army Corp estimates.
    I recently attended a conference featuring and had dinner with John Englander (http://www.johnenglander.net/) who warns that this loss of land-based ice could be catastrophic over the next centur(ies). If he is correct, or his concerns are well-founded, what this means me is that geological time scales (I.e. millennia) are being collapsed on to human/engineering time scales (i.e. decadal). Further, if this is true, I find it extremely wasteful to upgrade the infrastructure of cities to protect against, say, the end-of-century sea level rise projections.
    Essentially, given the intersection of geological and engineering time scales, I demand that engineers work to dream up a solution to contain land-based. I am talking seawalls around Antarctic and Greenland with pipelines to pump fresh water to places that need it. Cloud seeding or putting up solar reflector shields to keep the ice cool, etc. etc.
    Joseph Faries P.E., M.CE, CFM, M.ASCE
    Coastal Engineer
    Stantec Consulting, Ltd.
    Laurel MD
    (301) 785-5844
  • 14.  RE: Climate Change
    Posted 03-02-2017 09:39 AM
    Has variability changed?  For Southern California rainfall going back to Mission records beginning in 1760, no.  Yevjevich self-stationarity tests show no significant change.  Linear regression slope is indistinguishable from zero, meaning the rainfall trend is neither drier nor wetter.
    Sierra snowfall data going back to Central Pacific RR data beginning in the 1870s show the same thing.
    Sea level?  That depends on tectonic and coastal uplift or subsidence effects.  Sea levels for individual tide gauges can be visualized at this site:
    SeaLevel.info
    Sealevel remove preview
    SeaLevel.info
    February 9, 2017 - The Next / Previous buttons on the sea-level analysis pages now do a better job of taking you to a related page (e.g., another site in the same country/coast).
    View this on Sealevel >
    Neil Jordan P.E., D.WRE, M.ASCE
    Civil Engineer
    Irvine CA
    (949) 857-2184
  • 15.  RE: Climate Change
    Posted 03-02-2017 11:56 AM
    The original question seems to imply the assumption that climate changes, driven by global temperature change, can be observed by variability in local weather. This is true, but only in a very general sense. While local temperature and precipitation records may be an indicator, they represent at best, a very gross measurement. I would therefore respectfully caution against making any generalized statements about veracity of global temperature change conclusions simply on the basis of observed local weather phenomena. (Incidentally, I have personal distaste for the use of the term "climate change" in place of "global warming". Global temperature change is a cause; climate change is an effect.)
    David Booth P.E., M.ASCE
    Civil Engineer
    CLSI
    Westminster MD
    (410)871-4472
  • 16.  RE: Climate Change
    Posted 03-02-2017 03:58 PM
    The climate is changing, and it is being driven by greenhouse gas emissions. Yes, I know there is a collection of "evidence" out there "debunking" climate change. 25 years ago when it first started getting headlines, there was a lot of hokey research and predictions, and I personally debated against it a couple times. However, the current state of the art is impressive. I am "not a climate scientist". However, I am water resources professional with 40 years of experience, who teaches fluid mechanics and heat and mass transport, and has reviewed the literature and the modeling. The climate modeling community has their act together and is putting out good, usable results.
    While the impact predictions still have some uncertainty, the worst impacts, increase in temperature, increase in severe weather, and increasing sea level rise are really not being debated by the scientific community. We are not talking about a few millimeters of sea level rise, we are talking about a meter due to melting land ice (and a little due to decreasing sea water density). We are not talking about running the air conditioner a little longer, we are talking about failure of some crops in some locations. We are not talking about more spring showers, we are talking about more Hurricane Sandys.
    Regardless if you think we should try to reduce CO2 emissions, it is time the entire water resource community inform the public about the changes they can expect. Florida needs to build sea walls and Nebraska needs to plan for higher irrigation demands.
    FYI, the one common misconception is there will be drought everywhere. Not quite really. The two specific locations where my students have looked, Kansas and Niger, average rainfall will be about the same. It is just the evaprotranspiration will go up resulting in higher irrigation and lower stream base flows.
    Glenn Brown Ph.D., P.E., D.WRE, F.EWRI, M.ASCE
    Oklahoma State University
    Stillwater, OK
  • 17.  RE: Climate Change
    Posted 03-03-2017 11:45 AM
    I would like to alter this discussion slightly from the broader discussion of whether climate change science is right or wrong. The practice of engineering risk, and risk in general, includes two very pertinent topics related to climate change: (1) perceived risk; and (2) actual risk. Percevied risk is what we as humans do to "calculate" the potential risk associated with our decisions. These calculations are primarily instinctual, intuitive, and based in emotions/feelings. Actual risk is based on actual scientific studies, which in their most basic form, determine the probability an event will occur, and the uncertainty associated with that probability. Here is a link to a great article explaining the difference: http://journals.sagepub.com/doi/full/10.1111/j.1467-8721.2006.00461.x. A great example of human use of perceived versus actual risk is our daily use of cars. The perceived risk of driving a car is fairly low because we as humans do it often and can "mitigate" the risks in real-time. The actual risk of driving a car is fairly high and even with modern safety features, driving is still one of the most dangerous activities humans partake.
    So how does this all relate to climate change? Whether or not the discussion focuses on anthropogenic or natural causes of climate change, whether people want to believe in the science that proves climate change is real or the science that debunks it, we as engineers and scientists, by moral and ethical standards, have a duty to the public to evaluate the risk associated with both results and determine if that risk is actionable. Both the science that proves climate change is real and the science that debunks it are in agreement that the large or small changes that are occurring present actionable risk to the public. Therefore, it is high time the public, especially scientist and engineers, move past this short-sighted discussion of the reality of climate change, and transition into the more meaningful discussion of how to mitigate, and better yet, adapt to the risk. We, as humans, are averse to change, but those who adapt survive. In the words of Albert Einstein,
    “The measure of intelligence is the ability to change.”
    Jonathan Kimchi, EI
    Greenwood Village CO
    (303)590-9140 EXT 1608
  • 18.  RE: Climate Change
    Posted 03-06-2017 09:38 AM
    I received a message that the link to the article is not working. Attached is the pdf of the article.
    Jonathan Kimchi A.M.ASCE
  • 19.  RE: Climate Change
    Posted 03-06-2017 11:02 AM
    The issue with climate change is not that it is happening, but the cause of the occurrence.  Climate change is always happening and will always happen.  As a Chemist as well as a Civil Engineer, there two key facts which prove that carbon dioxide is a result of temperature increase and not the cause.  The first has to do with a very simple principle which all chemists understand:
    • The reaction between carbon dioxide and water (and other sequestration matrices) is an example of an equilibrium reaction:
      CO2 (g)   + H2O (l)  = H2CO3 (aq)
    • The following changes to the equilibrium system will have the following effects, with each effect obeying Le Chatelier’s principle by opposing the change:
      • As the forward reaction is exothermic, an increase in temperature causes the system to move in the reverse direction.
      • As the forward reaction is exothermic, a decrease in temperature causes the system to move in the forward direction.
      • An increase in the concentration of carbon dioxide or a decrease in the concentration of carbon dioxide causes the system to move in the forward direction.
      • A decrease in the concentration of carbon dioxide or an increase in the concentration of carbonic acid causes the system to move in the reverse direction.
      • An increase in pressure causes the system to move in the forward direction.
      • A decrease in pressure causes the system to move in the reverse direction.
    • Thus, the solubility of carbon dioxide in water (and any other matrix) is dependent on temperature, concentration and pressure.
    The second has to do with the effects of volcanic activity, which empirically demonstrates the above facts.  When a large volcano erupts, the amount of carbon dioxide released is extraordinarily large.  Some volcanos have released more carbon dioxide into the atmosphere than the human race has ever generated in its entire, say 5,000 year, history.  However, the above chemical equilibrium causes all of the carbon dioxide to go into sequestration.  The same is true for all of the carbon dioxide generated by human activity.  In fact, there is over 40,000 times the amount of carbon dioxide sequestered in the earth's crust and the oceans (and ice) as there is in the atmosphere.
    So, as the temperature increases, the concentration of carbon dioxide goes up.  This increase in carbon dioxide concentration is caused by the natural  temperature increases that have occurred since the mini-ice age in the 1400's.  The cause of those temperature increases, as always, is a change in the activity of the sun, and/or, the orientation of the revolutionary axis of the earth with respect to the sun.
    Patrick Vasicek P.E., M.ASCE
    Corporate Inspiration
    Bainbridge Island WA
    (360)479-5600
  • 20.  RE: Climate Change
    The essay by Patrick Vasicek is one of the best refutations of the left's "climate change" narrative I've seen. I wonder how they continually get away with the big lie.
    Timothy Doyle P.E., F.ASCE
    Civil Engineer, Retired
    Bluffton SC
    (843)705-2350
  • 21.  RE: Climate Change
    Posted 03-07-2017 12:52 PM
    Mr. Vasicek's discussion is technically correct, but simply a second or third order process in the CO2 mass balance. While obviously a good chemist, he has not demonstrated any knowledge of continuum systems in heat and mass transfer, much less climate science per se. Lakes and oceans are not saturated with CO2; far from it. They are not degassing. They are increasing their CO2 content as the atmospheric concentration increases.  As far as volcanoes, any geologist will tell you that recent activity is not that big a deal from a historical viewpoint. CO2 is increasing in the atmosphere because we are burning up fossil fuels in a few generations that took hundreds of millions of years to accumulate through geologic processes.
    Folks, we wouldn't let a shoe salesman sign off on the design of a bridge. What makes us so "special" to doubt the education, knowledge, experience and hard work of other hundreds of professionals who have dedicated their lives to understanding our environment?
    Stillwater, OK
    (405) 744-8425
  • 22.  RE: Climate Change
    Posted 03-08-2017 09:36 AM
    According to USGS (https://hvo.wr.usgs.gov/volcanowatch/archive/2007/07_02_15.html), volcanoes contribute about 200 million tons of CO2 annually, while global fossil fuel emissions for 2003 produced 26.8 billion tons of CO2, so volcanoes contribute less than 1% of annual CO2. There may be chemical reactions that use CO2, but the fact that we still have CO2 in the atmosphere (and increasing amounts at that) shows that we can't rely on sequestration to save us.
    Andrew Weaver P.E., M.ASCE
    Lancaster PA
    (717) 892-6835
  • 23.  RE: Climate Change
    Posted 03-09-2017 10:17 AM
    At current rates of consumption, fossil fuels will eventually be depleted.  If we make a concerted effort to switch to clean renewable energy sources now, the only risk we're taking is possibly switching somewhat earlier than absolutely necessary.  If we instead make a concerted effort to abandon clean renewable energy and place our chips on the side with old-money billionaires that are used to making their money from oil, coal and natural gas mining - we risk creating social pandemonium when the wells finally run dry - and destroying planet earth - the only known residence of living organisms.
    Best Regards -
    Rich Horstmann
    (720) 469-9610
  • 24.  RE: Climate Change
    Posted 03-10-2017 10:43 AM
    Agreed, Rich Horstmann. To the yeast in a petri dish the supply of sugar is infinite... until it isn't. Hopefully we're smarter than that, but I have my doubts.
    Lancaster PA
    (717) 892-6835
  • 25.  RE: Climate Change
    Posted 03-08-2017 09:44 AM
    Well stated.
    Furthermore, I would expect to see references to conspiracy theories (which are preposterous on their face) to appear on random internet chat rooms, but not on an ASCE or any other technical society's forum.  We really should be better than that.  As engineers we should know where to look for accurate information.  Some are failing here.
    Natural Systems Engineering, PLLC
    Syracuse NY
    (315) 425-9347
  • 26.  RE: Climate Change
    Posted 03-08-2017 10:19 AM
    A simple explanation of the effect of CO2 vs. the oceans is the "warm coke" effect.  As the ocean temperature rises, CO2 is (net) forced out.  However, there is a continuing two way flux, in at the poles and out at the equator.  It is huge compared to the anthropogenic source of CO2.  As sea ice melts and more cold surface is exposed, more CO2 goes into the water as well.  However, it has to keep up with the reduction in convection.  As we will recall, moist air weighs less than dry air.  Reduction in evapotranspiration from forest removal and destruction of arable land reduces convection. Convection is a large part of the removal of heat from the surface to the mid-troposphere.
    Also, in the troposphere photons in the relevant CO2 band are only produced on the surface and travel only a couple of hundred meters or so, on average.  Prior to release by an excited molecule, a molecule will have thousands of collisions, dissipating that energy,  This is reversed in the stratosphere where the molecules gather energy and usually emit said photons, sometimes out to space hence cooling the stratosphere.
    Here's an excellent site on the chemistry:
    http://www.barrettbellamyclimate.com/
    There are indeed hundreds of highly educated professionals studying climate. However, as the old adage goes, continuing on in education like that people tend to focus on their interests, "learning more and more about less and less".  There is a subconscious desire to make their studies important (and more than just to get further grant money).  Climate is incredibly complex, and frequently their analyses begin with "all other things being equal."  Of course they're not equal.
    I started studying climate 20 years ago because of my concerns.  The biggest thing I discovered is that the climate picture(s) are incoherent.
    Semi-Retired
    Rio Rancho NM
  • 27.  RE: Climate Change
    Posted 03-08-2017 09:37 AM
    The assertions regarding human vs. volcanic CO2 emissions are not supported by best estimates from USGS.  volcanic CO2 emissions appear to be two orders of magnitude less than current human emissions.  https://www.scientificamerican.com/article/earthtalks-volcanoes-or-humans/
    Stuart Schwartz A.M.ASCE
    Sr. Research Scientist
    University of Maryland Baltimore County
    Baltimore MD
  • 28.  RE: Climate Change
    Posted 03-08-2017 02:13 PM
    I think it is very important for every ASCE member posting here to please refer to the following ASCE Policies (with web-links provided below)
    Policy Statement 360 - Impact of Climate Change
    Policy Statement 488 - Greenhouse Gases
    I for one fully agree with these ASCE Policy Statements.
    Bob Schreiber
    ASCE
    Asce remove preview
    ASCE
    Approved by the Energy, Environment and Water Policy Committee on February 3, 2015 Approved by the Public Policy Committee on February 25, 2015 Adopted by the Board of Direction on July 18, 2015 The American Society of Civil Engineers (ASCE) supports: Government policies that encourage anticipation of and preparation for impacts of climate change on the built environment.
    View this on Asce >
    ASCE
    Asce remove preview
    ASCE
    Approved by the Transportation Policy Committee on December 18, 2015 Approved by the Committee on Sustainability on March 8, 2016 Approved by the Energy, Environment and Water Policy Committee on April 18, 2016 Approved by the Public Policy Committee on August 10, 2016 Adopted by the Board of Direction on
    View this on Asce >
    Robert P. Schreiber, P.E., BCEE, D.WRE, M.ASCE
    schreiberrp@...
    Former ASCE Representative to the Federal Advisory Committee on Water Information (ACWI)
    Current Non-Federal Co-Chair of ACWI's Subcommittee on Ground Water (SOGW) and ASCE's representative to the ACWI-SOGW
  • 29.  RE: Climate Change
    Posted 03-10-2017 11:25 AM
    I am not going to argue the merits of preparing for climate change.  We should be prepared for any reasonable potential issue.  Climate change as a human centric scientific principle has plenty of places to argue with.
    That being said, we do need to prepare for the effects of climate change.  The world is warming slightly, the seas will rise slightly, droughts will happen where they are uncommon, flooding will happen in unusual intensities, all as a consequence of natural cycles.  This is a result of applying a few hundred years of data to predict the future for a multi-thousand year cycle.
    What man has changed is the amount of damage that these changes can create when they occur.  We have billions of non-nomadic people trapped in areas of potential high impact in structures and lifestyles that depend on transportation of goods over very large distances.  We don't have the ability to pack up and move on that was once used regularly by our ancient ancestors.  And we don't have the universalist lifestyle that allows use to do everything we need to survive in a single family group.  Therefore civil, environmental, and cultural experts need to design systems that can withstand changes in "natural" conditions, because the only constant in climatology is that it will be different than it was before.
    Dwayne Culp P.E., P.Eng, M.ASCE
    Culp Engineering, LLC
    Richmond TX
    (713)898-1977
  • 30.  RE: Climate Change
    Posted 03-10-2017 03:01 PM
    I certainly agree with a large amount of the two policies shown, however, a critical review shows exactly the type of inconsistencies I was talking about.  I agree with "Informing practicing engineers, project stakeholders, policy makers and decision makers about the uncertainty in projecting future climate and the reasons for the uncertainty." and "Developing a new paradigm for engineering practice in a world in which climate is changing but the extent and time of local impacts cannot be projected with a high degree of certainty" as well as "Improving energy efficiency and reducing GHG emissions produced by infrastructure systems over their entire life cycles by making cost-effective use of existing and emerging technologies." with the emphasis on cost effectiveness.
    But what is "cost effective" when the uncertainties are so large?  This paragraph highlights the incongruity:
    "It is clear that climate change will create significant costs and extraordinary future risks to society and natural systems. Climate change puts the well-being of people of all nations at risk. Continued increases in GHG concentrations will heighten risks to public health and safety. Delays in action will increase costs and foreclose options to reduce the risk to future generations."
    The first sentence talks about climate change (I think most of us agree climate changes naturally).  The second talks specifically that GHG concentrations will heighten risks. I think most all of us agree with that, except some are skeptical of the degree of that heightening.  The third talks about increasing costs and foreclosing options, but in light of the uncertainties especially of local effects, what is cost effective?  Cost effectiveness is a definition of engineering, is it not?
    China is accelerating the building of coal powered electricity generation plants.  If we discard the concept of cost effectiveness are we not discarding the true definition of engineering?  I remember a professor of mine giving the definition of an engineer as "someone who can, with one dollar, build what anyone can build with ten.  How are we to remain (or again become??) competitive in the world market?
    Climate science is in its infancy.  We need more research, more powerful computers, more interaction between disciplines.  Do we want Civil Engineers to be seen as believers in the hockey stick, when temperature changes led CO2 changes by a thousand years, that believed an effect can precede a cause by a thousand years?  I don't think so.  I think the answer is to support more and better research.
    When some scientists say last month was the "2nd hottest February every" yet satellite data show it as the 4th warmest in less than 50 years, who are we to believe?  Altered numbers or hard science?
    There are alarmists, there are deniers, and then there are skeptics in the middle.  Hard core alarmists will lump skeptics in with deniers, and hard core deniers will lump those skeptics in with alarmists.  It's a subconscious thing.  Education is the key.
    Lots more, but enough for now...
    Semi-Retired
    Rio Rancho NM
  • 31.  RE: Climate Change
    Posted 03-10-2017 03:33 PM
    Oops - I lumped together the first and second sentences in that second paragraph quote.  Obviously I meant the first two sentences were about climate change and the 3rd about GHG's heightening that risk.
    Semi-Retired
    Rio Rancho NM
  • 32.  RE: Climate Change
    Posted 03-11-2017 03:33 PM
    Since the institution was set up by President Lincoln over 150 years ago, the National Academies and other national institutions have been advising the government and the public on important issues pertaining to science, engineering and technology. To address these sorts of issues, they draw on the best and most respected scientific and engineering minds in the country, uses accepted and transparent scientific methods and practices, and produces well researched and reviewed reports that policy- and decision-makers can rely on.  Most of the time, policy- and decision-makers don't have the luxury of waiting until all the facts are in.  They need to respond quickly, taking into account the seriousness and urgency of the issues at hand.
    So, on the issue of climate change, one would expect the policy/decision folks (even us engineers) would look to those national institutions and others to get advice from the best on this important and controversial issue.  One would expect lots of discussion, weighing huge uncertainties against the need to make decisions that have far-reaching effects on our nation.  Wow!  Heavy burden.
    But, if they (we) had, they (we) would learn that the National Academies and others (e.g., NASA, NOAA) have come out publicly and said the science is effectively settled:  the climate is changing significantly, that change is overwhelmingly human caused (burning of fossil fuels), and if we don't do something soon, the impacts will be devastating.  Whatever residual uncertainties exist, they are inconsequential compared to the consequences of inaction.  This nation’s (and the world’s) task should now focus on the hard part: dealing with climate change mitigation and adaptation. See http://nas-sites.org/americasclimatechoices/. The equivalent organizations in the other developed nations have reached the same conclusions.  The Intergovernmental Panel on Climate Change (IPCC), to which National Academy members are a part, has also reached the same conclusions, and has assembled a vast and compelling set of peer-reviewed research and publications to back it up.  In the U.S., the 40 or so other professional science and engineering societies, including ASCE, have issued policy statements stating that climate change is a real, human caused and an urgent problem.
    All of the reports of the Academies, the IPCC, NASA, NOAA and others are available free of charge on their respective websites.
    So, out of curiosity, why are we having this discussion?  Sure, we all should be skeptics.  But, with skepticism comes the responsibility to be skeptical about stuff in our areas of expertise.  Sure, it's okay to raise issues but let's at least ground them in the currently accepted state of the science.
    BTW, on the above National Academies link to climate change, if you want to check it out, I suggest you do it soon.  I checked the link before submitting my reply and found that they are moving a lot of their links to Facebook.  My guess is that it's in response to the policies of the Trump administration.  Think Fahrenheit 451.
    William Wallace ENV SP, F.ASCE
    Wilsonville OR
  • 33.  RE: Climate Change
    Posted 03-12-2017 07:45 PM
    My father was an engineer and at one time he got involved in politics when he became campaign manager for a friend running for county commissioner in rural western Maryland.  I don't recall the specifics of the issue but I remember him coming home (when I was a high school student) and telling me that sometimes you will have all yours ducks lined up and your argument is a solid as can be but some people will look you square in the eye and say: "My mind is made up.  Don't confuse me with the facts"
    Harley Winer Ph.D., P.E., D.NE, D.PE, M.ASCE
    Retired
    New Orleans LA
    (504) 482-9678
  • 34.  RE: Climate Change
    Posted 03-14-2017 03:56 PM
    As engineers, we tend to apply logic to our arguments as though it were the only way to look at things.  Our spouses will probably attest as to how maddening that is.  We err when we overlook the emotional, cultural, and social aspects of our projects or designs.
    In addition, there is a difference in how people of differing political stances look at things, i.e. the liberal says look at those poor people, we should do something to help them, whereas the conservative says look at those poor people, we should help them to do something.
    William Forbes D.Eng., P.E., M.ASCE
    Virginia Bch VA
  • 35.  RE: Climate Change
    Posted 03-16-2017 03:26 PM
    That is a very clever distinction - the difference between doing something to help someone versus helping them to do something.  Much like the difference between giving someone a fish or teaching them how to fish.  BUT there are those you say "screw them!  They should figure it out themselves" or worse seeing them as vulnerable and easy prey to be ripped off.  By this I infer that much of the denying of the effects of fossil fuel upon the atmospheric concentration of CO2 and the effect of CO2 upon the climate of our home planet, is greed based - an inconvenient obstacle to making money
    With respect to climate change, we as engineers designing infrastructure for the benefit of commerce and society as a whole, need to recognize that many (perhaps most) of our projects are decades in the making from initial conception to final realization.  As such, recognizing that the climate is changing, we need to start NOW to incorporate an understanding of carbon into our designs.
    Retired
    New Orleans LA
    (504) 482-9678
  • 36.  RE: Climate Change
    Posted 03-11-2017 03:17 PM
    Arguing about the proportional contributions of volcanic CO2 and human CO2 misses the point.  We can't control volcanic emissions but society has the potential to reduce human CO2 if (and certainly a really big IF) carbon is included in our designs and policy were to be be more considerate of the public good than the greed of certain sectors.
    Retired
    New Orleans LA
    (504) 482-9678
  • 37.  RE: Climate Change
    Posted 03-11-2017 03:16 PM
    My response is to Mr. Vasicek,
    following on your comment and in looking for solutions, is there a way to parcipitate out the CO2 stored into the oceans in the form of calcium carbonate? There are vast quantities of CaCO3 rock that have been deposited which we use not only as rock but in the production of cement. I am not a chemical engineer but am fascinated with it, I have concerns with not only climate change but ocean acidification. If you could develop a process that not only helps remove the CO2, but also has an economical benefit, at least there would be a drive to do it. Would it be feasible to do on a massive scale? Is it just the sea creatures with shells that do it on a geologic time scale or could we add calcium to the process to parcipitate out the CO2? Anyone else think about this?
    Jason Gowland P.E., M.ASCE
    Senior Engineer
    GSE Engineering
    Williston FL
    (352) 486-1197
  • 38.  RE: Climate Change
    Posted 03-11-2017 03:37 PM
    Dr. Keaton,
    You asked 2 questions; first, "...the world has been warming since the end of the last ice age, right?"
    No. For the millennium preceding the last 150 years, for example, global temperature was on a downward trend.  More importantly, one could just as correctly say that global temperature has decreased over the last 120k years.
    Depending on the period you look at, and the scale you use, you can say that the world has been cooling or warming.
    The amount of warming we have seen is less relevant than the rate.
    The rate of warming experienced by our planet over the last 150 years is 10 to 20 times higher than any time in the last million years.  The exact multiple can be debated, but the story will not change. We are experiencing an unprecedented rate of warming.
    If we wait until we see global temperature higher than ever before, we may be in the midst of the global extinction of complex life.
    The ability to anticipate a problem and stop it before it kills us is something that distinguishes us from bacteria. Let's be better than bacteria.
    Your second question, "Is the weather variability we see today the same or different?"
    Same as or different from what? Weather and climate are not the same.  In California, we are seeing a shortening of the rainy season, less snow, more intense rains when they come, hotter heat waves, hotter droughts, comparing the last 2 decades to the previous century.  All of these are linked to ocean surface temperature, but weather isn't the problem.  The extinction of the biological support system that provides us with clean air, water, and food is the problem.
    Aaron King
  • 39.  RE: Climate Change
    Posted 03-12-2017 07:39 PM
    We have skilled scientists generally agreeing on predictions of warming, and have done so for 25 years.  Science goes beyond speculation. How have the predictions matched reality, i.e. the 10- and 20-year predictions from 10 and 20 years ago must be on record.  Do they fit current observations?
    Pat Daly P.E., M.ASCE
    Engineer
    Wince-Corthell-Bryson
    Kenai AK
    (907) 283-4672
  • 40.  RE: Climate Change
    Posted 03-12-2017 07:44 PM
    Climate warming has been an issue for some 25 years.  In that time, there has been much studying (and arguing) of what it all means, and predictions of what will happen.  I see writing above of science, consensus, volcanoes, etc.-- i don't think these arguments are very important at this stage--we don't know enough, and may continue to disagree for some time while we work it out.
    Science is not "correct" because of  the predictions, but the accuracy of them.
    What do they--typically models--predict? Have the models from 15 and 25 years ago been accurate, or reasonably so?  When they predict an annual temperature rise, with varying amounts of certainty, where does reality fall? When they predict more or fewer of certain weather patterns, do they come to pass (generally) as predicted?
    I don't know, but it looks like many of you above might.  If the models predict correctly it does not matter why they are right as long as they continue to predict accurately; we should react in accordance with them until they fail, or until we discover the other reasons the models happened to align with reality.  If the models have not been right, it does not matter how great the consensus or how heavy the pile of papers declaring they should be;  we need a new outlook.
    -my 2 cents.  I tried to post earlier, but don't see it here. I don't know if it is awaiting moderation (the "rules of engagement" say the site is not moderated), but if this somewhat more wordy post is a duplicate, my apologies.
    Engineer
    Kenai AK
    (907) 283-4672
  • 41.  RE: Climate Change
    Anthropogenic Global Warming
        Before joining in the national political sport of name calling, backbiting, and sloganeering, the first question that one should clinically address is: ‘are human activities responsible for the observed increases in world temperatures over the past century?’ There is no real question that the earth is warming. Some really competent members of the human race, now with the help of earth-orbiting satellites, have gotten very good at measuring temperature.
         I am not qualified to answer that pivotal question. I am not even in the game. To really be ‘in the game’, one must actually examine historical data, read volumes of pertinent technical literature, develop and test one’s own mathematically-based hypotheses, and, finally, publish the results of one’s calculations and models in peer-reviewed scientific literature where they can be challenged and, possibly, refuted. From a strictly scientific standpoint, those who cannot or will not sacrifice the time required to formulate the problem in this fashion might be considered dilettantes, somewhat like the loud and shirtless fans criticizing the action at a football game.
        Instead, in our democratic society, even with questions of this magnitude and complexity, we are inclined to put them to a public referendum. Pundits abound. Scientific illiteracy is no barrier. Even the third graders at elementary school may voice their opinions for the media.
        For a politician, a decisively held opinion on the matter of global warming is essential. Often, for those dreading the economic impacts of mitigation, the answer to an anthropogenic warming component is a resounding 'No!'
        Still, some concerned scientists and engineers have given the matter serious thought. After consideration, the American Chemical Society published their study group’s consensus in a policy statement entitled, Global Climate Change.
        In calling for the development and application of technology to “cost-effectively (most ACS members are keenly aware of the costs of energy and materials production) protect the climate”, the ACS policy statement argues that “deploying these technologies would reduce energy costs, increase productivity, improve the U.S.’s energy independence, improve air and water quality, and reduce environmental hazards, in addition to reducing greenhouse gas emissions.” Considering the multiple ancillary benefits, one might imagine that government sponsorship of the application of these technologies would be welcomed even were greenhouse gases not reduced.
        Addressing the probable impact of human activities, the ACS policy statement concludes: “The overwhelming balance of evidence indicates that reducing greenhouse gas emissions is the prudent and responsible course of action at this time.” Moreover, “ACS believes that public and private efforts today are essential to protect the global climate system for the well-being of future generations.”
        However, pursuing a prudent and responsible course of action in America is difficult because, when facing a national policy involving a change in lifestyle (particularly, requiring conservation), many U.S. citizens do not respond solely as ‘Americans’. Some super-elevate the economic interests of their state; some consider solely those of their city; others, still more narrowly, of their individual business or occupation; while the meanest among us defend our interests alone.
        To the besieged administrator who adopts his primary accounting stance as ‘defender of the state/community/business/university budget’ rather than the steward of the future economic welfare of the nation, it might seem reasonable to not only oppose any measures which threaten to increase financial burdens, but, further, to argue that the problem is debatable -- and may not even exist.
        It has always struck me as especially odd that many of us who most enjoy the prosperity brought by modern technology (and who also have faith that future technological developments will overcome current material and sociological problems), will turn to vilify those in that community of technologists when confronted with a message they prefer not to hear.
        That seems a lot easier to do when you are not in the game.
    John O'Connor, D.Eng., P.E., F.ASCE
    CEO
    H2O'C Engineering
    Columbia MO
    (573) 234-1012
    John@...
  • 42.  RE: Climate Change
    Posted 03-14-2017 11:41 AM
    There is a new concept being thrown about:  "Fake News."  It goes along with the emotional concept of "Perception is Reality".  We as engineers should be better than that.  If the current perception turns out to be false what will history have to say about civil engineers?  I could agree that 97% of climate scientists believe there is an anthropogenic factor in changing climate now, but that doesn't mean 97% of climate scientists believe human emissions of CO2 are the predominant factor, and that it will be devastating.  Fits nicely with the concept of Original Sin, but that's religion.  Belief is a religious thing and has no place in science.
    Another concept worth reviewing is the "Broken Window Fallacy".  Can replacement of one energy source by another by seen as economically beneficial?  To be sure, coal power has its pollutants, e.g. mercury, SO2, NOx, etc., but let's not confuse the effort required to scrub those with reversing the exothermic reaction that creates CO2.  Engineers should know better.  And again, if the money that has gone into lining the pockets of those collecting tax breaks for producing widespread inefficient alternative energy solutions had gone into research instead might those methods now actually be more efficient?
    Uncertainties in climate science are huge, and when applied locally are even larger.  We should not let environmental considerations be hijacked
    by those wanting to make a quick buck.
    Semi-Retired
    Rio Rancho NM
  • 43.  RE: Climate Change
    Posted 03-15-2017 11:22 AM
    Unlike Mr. Hemphill, I would like to try to avoid the ad-hominen approach to argument. But as Mr. Hemphill has added to his trove of half truths and alternative facts by suggesting that folks like the late Professor Steve Schneider are (were) motivated by personal gain, I must say that this is simply calumny. Mr. Hemphill's opinions on climate change are not shared by any of the National Academies, the scientific societies that address environmental issues like the AGU, nor nearly all of the scientists who study climate and its related sciences. See for example the Washington Post article - 'This ... follows from the basic laws of physics': Scientists rebuke Scott Pruitt on climate change
    Washington Post remove preview
    The controversy continues over Environmental Protection Agency Administrator Scott Pruitt's statement Thursday questioning the most important scientific conclusion about climate change - namely, that it is driven by human beings.
    View this on Washington Post >
     The letter referred to in the WaPo article was written by a pretty august group of scientists (some of them my colleagues) - it can be found at
    https://www.dropbox.com/s/x73rror6yxh779o/scientists_letter_Pruitt_20170313.pdf
    Dropbox remove preview
    View this on Dropbox >
    There really isn't anything more to say except to reinforce the view that our job as civil engineers is to do our best to help society deal with the problems climate change is dealing us, e.g., ever more dramatic swings here in California between floods and droughts. As an aside, towards the end of his life, while continuing to challenge the Exxon and Koch supported view that anthropogenic climate change was not real, Steve was also working to develop approaches to climate adaptation.
    Stephen Monismith A.M.ASCE
    Prof
    Stanford Univ
    Stanford CA
    (650) 723-4764
  • 44.  RE: Climate Change
    Posted 03-16-2017 12:17 PM
    I would like to humbly submit to my esteemed colleagues from both sides of the aisle that no matter what stock you put in the anthropogenic role in climate change, the world, especially its coastal centers, is facing unprecedented human and ecological challenges. We, as Civil Engineers, have a clear mandate to respond to these challenges armed with the most defensible data gathered and processed by the most reliable tools we have at our disposal currently. At the same time, we must continue to discover more fundamental truths and improve the methods of their unambiguous interpretation.
    Whether anthropogenic influence on the changing climate landscape is real or not will, like any other contentious issue in the mainstream consciousness, be debated without a clear consensus for a long time to come. Led by populists and provocateurs from both sides of the coin, the truth will likely remain mired in conspiracy theories and half researched paper trails on the side of the naysayers and accusations of vested interests and a rather sanctimonious attitude on the side of its champions. Rather than question the bias inherent in an effort - after all, who does not have a vested interest in this planet? - I would suggest we interrogate a piece of information as thoroughly as we can and attempt to appreciate the intrinsic merit or lack thereof in it. Only in this way can "data" be unearthed from information, and only in this way can the true import of an action in response to that data be fully understood.
    To get caught up in the whirlwind media hype which relies on sources which cannot stand the sternest tests of induction, logic and inference is to let go of one's industry. As Civil Engineers, we have been trained to think everything through from first principles. It behooves us to be very careful in what information we disseminate to our peers and to the general public. The onus is upon us to apply the best scientific and engineering practices to data as well as its interpretations. I firmly believe that if a Civil Engineer can be held accountable to a code of ethics for the safe delivery of a bridge or building with maybe a 1000 lives at stake, then so too must they be held to the same moral code of conduct for shaping thought leadership in an issue which could potentially affect the fate of  all humanity, and indeed, all life as we know it.
    The stark reality is that sea level rise is threatening the island nations, Alaska and the Antarctic ice cap with submergence within our lifespans. The naked truth is that the Everglades and mangrove forests around the world are migrating and shrinking at an alarming rate. The dismal outlook of uncertainty associated with increasingly frequent extreme weather and uncharacteristic weather events is making life, especially subsistence dependent life, a nightmare in the American Midwest, the Pacific Northwest, the Asian subcontinent and the Far East among other places. The coral reefs - our oceans' lungs and the world's kidneys - are being bleached out of existence even as I write this. Whether or not this is because of anthropogenic climate change is a moot point. If practices such as a greater investment in renewable energy, cleaner forms of transportation, more sustainable agricultural and aquacultural practices, and more efficient urban constructions are in the portfolio of our stewardship of this world, we should do everything in our power to advance these practices.
    Godspeed.
    Vamsi Krishna Sridharan A.M.ASCE
    Postdoctoral Scholar
    Institute of Marine Sciences
    University of California, Santa Cruz
    Santa Cruz CA
    (650)862-2658
  • 45.  RE: Climate Change
    Posted 03-16-2017 03:29 PM
    I have been following with interest the discussions on climate change.
    It appears to me we have a two-fold dilemma.  Firstly, we understand that change is inevitable and is something that civil engineers design for on a normal basis.  Secondly, as pointed out, climate change is now occurring at an unprecedented rate, for which we will need new adaptive tools and creativity to manage.  On this second point, we are not unanimous on the primary cause, but it seems that the only GHG phenomena that we are closely linked to is the one that we call anthropogenic or man made.  In my opinion, we should at least attempt to control this source, regardless, as it will only benefit us all in the long run.
    When I scan through history and consider economic advances made by man (largely initiated through "king" coal), and the subsequent pollution caused by man through our increased standards of living, we can say that have come a long way in resolving the problems we created. And if we resolve to work with nature as we have proven ourselves capable, we can mitigate this second one. This is fundamental and is being continuously addressed now. We still as engineers must provide solutions to adapt to the fallout of climate change whatever its rate, and the first point is also a priority now.
    I stand by my profession and have great faith in all of us to sort it out.
    Harlan G. Kelly P.E., M.ASCE, B.C.E.E.
    KNE2 Ltd
    Vancouver BC
    (604) 669-5019
  • 46.  RE: Climate Change
    Posted 03-21-2017 01:24 PM
    No replies, thread closed.
    Again, I would like to emphasize that I do in fact agree with the science.  The problem here is the runaway alarmism created by statements with words like "could" and "might" etc.  There is no consensus that GHG's are creating dangerous global warming that will destroy Earth.  There *is* consensus that anthropogenic forcing is having a warming effect superimposed on the natural variability.  Some people don't get the difference.  The science includes the uncertainties.
    There are several anthropogenic factors contributing to climate change beyond CO2.  For one, it is easy to see the difference between the poles in pictures of polar ice.  Northern ice is discolored, southern ice is white.  Black carbon, dust, etc. settle on the northern regions.  China is still bringing on dirty coal plants at the rate of two per week - and by dirty I mean real pollutants like carbon, mercury, SO2, NOx, and others, not CO2.  Destruction of arable land is decreasing evapotranspiration, which is a major mode of heat transport from the surface to the mid troposphere via latent heat.  Then, there is the solar influence.  However, the solar influence is not in terms of energy, but matter.  Remember E=mc^2?  Finally, there are the uncertainties we don't even know of.  All of these things are happening in reality, but are ignored by alarmists.  Similarly, denialists ignore it all.
    There is *huge* uncertainty as to the relative effects of all these different factors.  Again, look at the uncertainties listed at the end of the IPCC Technical Summary.  That's the summary written by scientists, not the "Summary for Policymakers" written by politicians that actually came out before the Technical Summary.  Think about that.
    With all the uncertainty, how are engineers in the real world supposed to effectively deal with the subject?  Engineering is all about cost effectiveness, right?  If all the money that has been given for solar rebates etc. had been given for research into the climate models and solar panel etc. efficiency who doubts we would be way ahead of where we are now?
    Semi-Retired
    Rio Rancho NM
  • 47.  RE: Climate Change
    Posted 03-22-2017 12:14 PM
    "With all the uncertainty, how are engineers in the real world supposed to effectively deal with the subject?"
    We are in the business of dealing with uncertainty, addressing it through redundancy, factors-of-safety, standardized practices, and the like. I once had a decision-making level client angrily interrupt a colleague who was droning on and on about the limitations of his analysis on a project unrelated to climate change. She said something like "Stop talking about uncertainty. We NEVER get to make decisions based on complete information."
    White Plains NY
  • 48.  RE: Climate Change
    Posted 03-23-2017 12:24 PM
    Timothy brings up a point that, although obvious to most of us in the real world, may not be as obvious to others.  Factors of Safety vary depending on the uncertainty.  Geotechnical factors of safety are much higher than for structural steel, for example.  We know a lot about the steel, but can't really see very far into the ground.
    This is the basis for my argument.  While the scientists know about the uncertainties, some politicians are more likely to puff out their chests and discount it, claiming they know it all.  For those of us in the applied science profession (engineers), the IPCC Technical Summary with its uncertainties listed at the end is the more appropriate document.  If one is to only "plug and chug" maybe one is a technician and not an engineer.
    Climate is an interdisciplinary science.  When it comes to reality one cannot just take the stance of those who deeply study one aspect of climate science and follow the assumption "all other things being equal" because they're not.
    Climate research is cheap compared to expanding safety factors or applying global factors to local parameters (or building seawalls!).  When people ask what civil engineering is doing about climate change we should say we are arguing for more research, more integrated models and more powerful computers.
    Stephen Hemphill P.E., M.ASCE
    Semi-Retired
    Rio Rancho NM
  • 49.  RE: Climate Change
    Posted 03-15-2017 11:34 AM
    Here is my 2 cents:  We tend to conflate two questions when discussing climate change.  The first:  "Is it really happening/Are humans responsible"  and the second:  "What should be do about it".  The first question needs to be answered by those who study the phenomenon and is beyond opinion or belief.  The facts, while open to interpretation, will speak for themselves.  And in fact after 150 years or more of study, those who have actually spent the time and resources to delve into this question have concluded that yes, the earth is warming and the actions of we humans are a significant cause of that warming.  The second question can only be answered based on our values and beliefs and is beyond science.  Science indicates that the earth's temperature will increase, the earth's oceans will acidify, precipitation patterns will shift, dry areas will get drier, wet areas will get wetter, etc, etc.  Our values dictate what we should do about it.   There is a reasonable argument to be made for doing nothing.  This argument suggests that there is uncertainty in the predictions and thus we should not spend our limited resources to protect against something that may not happen.  If the climate does change the way it is predicted to change, we humans can develop a technical response that will protect us (build more air conditions, adjust water supply systems, increase flood protection, etc). You (and I) may disagree with this response, but that is what politics is for.  We engineers and scientists have a role to play in politics, but it is not to keep stoping our feet and demanding that everyone listen to the 'facts' that we have laid out.  We engineers and scientists too often forget that science is not the only way of knowing (as a previous commentator noted).  And sometime the 'logical' response is not the most appropriate.
    Robert Ryan Ph.D., P.E., M.ASCE
    Associate Professor
    Temple University
    Philadelphia PA
  • 50.  RE: Climate Change
    Posted 03-15-2017 08:02 PM
    As life member of ASCE and an energy-environmental engineering consultant, we as engineer have an obligation to provide peer-review based input to appointed and elected officials on issues that affect the Health and/or Safety of USA residents – the Climate Change Debate and concomitant engineering construction costs  Please see
    Recent peer review articles [April and May 2016] reflect a shift in scientific opinions on Global Warming and Climate Change.
    Goodwin. RW. “Recent peer review articles [April and May 2016] reflect a shift in scientific opinions on Global Warming and Climate Change” Oil Pro; June 5, 2016
    http://oilpro.com/post/24917/polemics-vs-peer-review-science-global-warming-and-climate-change
    Richard Goodwin Ph.D., P.E., M.ASCE
    Envir Engr Consultant
    Lake Worth FL
    (561) 432-9369
    Ph.D., P.E., M.ASCEEnvir Engr ConsultantEnvir Engr Consultant
  • 51.  RE: Climate Change
