The first question to ask is why are we pumping downhill? If at all possible, pump to the ridge line and grade the downhill line as an open channel gravity line. The worst case scenarios are where the highest point is near the beginning of the line, and there are one or more subsequent, but lower, high points. In those cases use dual combination air/vacuum relief valves at all high points with each sized to protect the line if acting alone. Add additional dual vacuum release valves on any long descending legs at appropriate intervals.
For clear water applications, and if flow is high enough to justify the economics, consider adding a small hydroturbine at the discharge to keep the hydraulic gradeline above the pipeline profile, and recover the energy through the turbine.
We do a lot of mining slurry pipelines, and this is a common problem. First choice it to pump to any highpoint and break the grade with surge tanks avoiding any sags where solids would deposit. Another option is to use a choke station at the discharge, but again only if velocities, when choked, are still above critical deposition velocity. Last choice is to accept hydraulic jumps in the descending legs and provide atmospheric air vents to ensure adequate air above the jumps. The Bureau of Reclamation has some good guidance on aerating pipelines. The pipeline liner has to be resistant to the increased turbulence. I don't particularly like/trust air/vacuum valves on slurry pipelines.
Raymond Hamilton P.E., M.ASCE, BCEE
Principal Engineer
Amec Foster Wheeler
Denver CO
(303)975-2195
Sent: 02-06-2017 17:38
Subject: Pumping Downhill
Just to kid you at first, I thought *@it flows down hill on it's own! Now seriously, the biggest challenge in pumping downhill is when there is a large high spot between the start and end of the force main-how do you deal with all the forces when the velocities get moving on the downhill side? Does a simple vacuum release device serve the purpose in all cases? Curious to read other comments.
Harold Dungan P.E., M.ASCE
PRESIDENT-H2Oaks Consulting LLC
Maxwell IN
Sent: 02-03-2017 10:17
I have designed pumping systems in the past which pumped downhill. However, I am always interested in avoiding unusual problems in unique situations. Has anyone come across a highly unexpected condition which added complexity to a system design for pumping downhill? How did you address the challenge?
Cecil Whitaker P.E., F.ASCE
PRESIDENT
Whitaker Engineering Pc
Indianapolis IN
(317) 823-9050
