Effects of high velocities in spillway chutes are often underestimated. The Oroville spillway will experience very high velocities which result in cavitation risks. This could eventually be avoided if the chute surface is entirely smooth without any offsets or local slope changes. However over years every perfect chute surface will show minor or larger deficiences and this might be the cause for cavitation erosion. The Oroville chute erosion damages I have so far seen on the internet do not allow to clearly identify cavitation as only cause for the damage. It could also be due to imperfect joints and stagnation pressures acting on the concrete slabs as uplift forces. Or it could be a mixture of the two.
I know from cases where, due to stupid mortar patches not removed after construction, cavitation erosion occured with not too high velocities. Therefore I would recommend aeration of chutes for all cases where velocities higher than about 25m/s will occur. If planned from the beginning it is a very cheap and entirely safe measure against cavitation. The Oroville chute has not a constant slope over its entire length but upstream of the damage an increase in slope is visible. Tendentially this would result in pressure reductions and would inccrease the cavitation risk.
When looking at the videos I also had the impression that shock waves and free surface flow aeration of the chute where not considered for the design of the side wall heights including a suitable freeboard. However this is somewhat speculative.
When I startet my professional career as an academic hydraulic engineer performing physical model studies we had experts in the board of experts of larger dam projects specialized in dam hydraulics. They were experienced in phenomenas like high velocity flows, shock waves, cavitation, free surface aeration, vortex formatition etc, This is not the case any more for nowadays projects even though the hydraulic effects have potentially higher risk for failures then dam static issues. I am a little bit disappointed that this damage happens in the US. I was myself one of the first ones working on free surface aeration in chutes and on spillway chute aeration using aeration devices. I know the expertise of the US Bureau of Reclamation (e.g. Hank Falvey and Warren Frizzell). I do not see that this expert know-how has in any way influenced the Oroville design.
Peter Rutschmann Aff.M.ASCE
Academic
Professor and Director, Chair and Lab of Hydraulic
and Water Resources Engineering
TU Munich
490049 8964911082
