New Mexico Section
  • 1.  Brick Weave Design
    Posted 06-14-2017 11:02 AM
      |   view attached
    I was recently asked to design a brick weave pattern wall similar to the attached picture.  It looks like it is a simple enough brick beam and column design with the brick weave pattern being infill.  However, once I started looking into the calculations this design became much more complicated than I thought.  Has anyone ever designed a wall like this before?  Is it possible to construct this wall as a double wythe or are the beam and column elements actually concrete and wrapped in brick?  Finally, is there a way to reinforce the brick weave pattern so that it can handle the out of plane wind load or someone kicking the wall?
    Pietre Hamblin-Hatchell EI, A.M.ASCE
    Chavez-Grieves Consulting Engineers
    Albuquerque NM
