The storage of the chambers and/or basins in combination with the outlet structure allow you to adjust the OUTFLOW Tc and Q. The inflow to the storage is determined by the developed conditions.
The outflow structure limits how fast the flow leaves the storage so you can approximate the pre-development hydrograph. Normally a low flow drain is used, sized to not clog due to debris. The opening may be large enough to pass a can or liter bottle or else have a trash rack. Two or more openings would pass various sized storms by limiting the max flow to the pre-development peak. Storage volume would have to be sized to hold the design storms. Definitely an iterative process as changes in storage depth may change outflow rate. Outflow design should be coordinated with structural design for buildable structure - simpler is better.
Depending on size of storage, many example designs are available at Federal, State, large municipalities as well as some pre-cast or other vendors. Many structure vendors are listed in stormwater related publications.
Item usually forgotten is that extended moderate flows (in channel) may cause more erosion downstream than passing the post-development peak (overbank flows for short period).
Check for timing of peaks downstream to avoid flooding due to multiple extended discharges from other storage areas. This problem cam be an issue in our area since multiple green field developments may discharge to the same stream network.
Remember every structure will need maintenance (sediment & debris removal, mowing), repair (infiltration layer replacement), and eventual major overhaul and/or removal. Allow for access & inspection. Don't allow buildings, etc. on top of anything that may eventually collapse - pipes, storage/infiltration units, etc.
David Moughton P.E., D.WRE, M.ASCE
SR PROJ MANAGER
XCG Consultants
Cincinnati OH
(513) 231-1931
