Here is an example I came across where a client was asked by the Mexican government to grout an existing dam. This governmental request came BEFORE (really?!?!?) they knew anything geotechnically about the dam. Some background to consider:
- Dam was built using alluvium and colluvium materials and compacted over near-surface bedrock.
- Dams are meant to seep and will last a long time if designed properly
- The dam had a clay core and a HDPE liner on the upstream face where it impounded water
- Dam had a seepage collection / underdrain pipe network installed at the base of the dam foundation to reduce saturation at the interface
The government agency was "demanding" a grouting program be performed because the dam had minor seepage at the downstream face and the impounded water was low Ph; improving the downstream water quality being the ultimate concern.
While I haven't gone into the deep details of the problem, here are some issues that needed to be considered to AVOID CATASTROPHIC FAILURE OF THE DAM!!!!!
- If the grouting does not create a deep curtain down to bedrock you are merely shifting seepage paths and pore pressures to a different zone in the foundation (possible stability problem)
- If the grouting isn't planned properly, you could plug off the seepage collection pipes
- If the grouting isn't planned properly, you can damage the clay core and actually increase seepage
- If you only grout the foundation (vs. the whole dam to the crest) you may change the seepage flow path to a shorter distance near the top of the dam and increase chances of local slope failures or piping.
- If the water or the soils are acidic, special concrete will need to be used otherwise the concrete will breakdown in a short period and make the improvements null.
It takes a seasoned contractor and engineering team to properly grout a dam. I haven't even mentioned the monitoring program needed to evaluate pore-pressures (effective stresses) before, during, and after construction. Analysis should be performed for both static and pseudo-static stability as well as seepage based on local regulations or commonly accepted best practices.
Randall Rice P.E., M.ASCE
Golder Associates Inc.
Reno NV
