Permeable Pavements and Open Grade Asphalt have been in used for over 40 years. The design requirements of the two have little in common other than the use of Asphalt as a binder. The structural carrying capacity, and test procedure to determent the proper amount of asphalt are different. Their acceptability varies through out the country. I design open grade asphalt and development my own method of determining the optimum asphalt content. It was used on airports and roads for skid resistance. The type, configuration, and gradation of the aggregate will vary with the problem you are solving with the project.
Permeable pavement has no business being considered in area of expansive soil, unless you have protected the subgrade from the flooding of the water. in the North, you are asking for terrible freeze than problems and subgrade failure during the thaw. In the south, coastal areas would work great. I have used it in the bottom of detention ponds that were parking lots, achieving two objectives. (sand and gravel base)
I worked with MO. DOT years ago and reduced accidents by 80% and a curving area of I-70 in Kansas City. By placing a open graded surface coarse over the existing concrete pavement.
Robert Hinton P.E., M.ASCE
Consultant
Tulsa OK
