Gents,
I am pleasantly surprised at the number of options and ideas suggested. I need to thank you before I go any further on this .
I've recently moved to Senegal (West Africa). The purpose of sharing is to invite ideas from different perspective. while I do believe that there are better options available, I do have constraints.
Hence, I need to find the best possible solution to deliver with available resources within the shortest possible time.
. Information /materials at hand:
- Terrain : Silty Sand CBR Value 20
- Backfill material : Laterite (locally available)
- Fencing post : 2inch GI Pipe (Locally available) (1.8m in total , 1.5 above ground and 30 cm embedded )
- Fencing Mesh : Diamond mesh (locally Available)
- Fence foundation : under discussion
- Equipment Available : JCB ( Backhoe)
Joram Amir & James Anderson :Thank you for the suggestion. I would definitely consider it. I do have a constraint, the equipment is not available in the local market. its only 60 cm deep, can I buy an Auger instead ?
Terrain is characteristics :
1) Clay (1st location)
2) sand (2nd Location)
I do need backfill, Laterite is an amazing material available locally which can be used for backfill. When I calculated the budget , backfill is turning out to be a cheaper option than concrete.
Robert Scancella:
Dear Robert,
Yes, the bottom is wider than the top. Standard fencing is 60 cm long (30 X 30) cm wide column. I have reduced the top width and changed it into conical shape. ( No edges ! )
Top of concrete diameter is 20 cm, bottom diameter is 35 cm. The bucket width of the backhoe is 40 cm. There is no effect on the excavation.
Abdul Muqtadir
Dear Abdul,
Absolutely! agree with you. That's the concept I am proceeding with! . will update the progress as it takes shape.
Thanks for the suggestions!!! Its a pleasure, will be back with more discussions.
Kalyan Emandi
Sr.Project Engineer
Senegal
