  • 1.  Student question: Using AI to help with bridge recovery for the people of Puerto Rico?
    Posted 01-16-2026 10:59 AM
    Hi everyone!
    I'm a student member finishing my Associate's and transitioning to the University of Akron later this year. I'm a Phi Theta Kappa member, and in my free time, I enjoy playing chess and doing research to help me grow as a future engineer.
    I've been looking into a major problem facing the people of Puerto Rico. The island's bridges have a D+ grade from ASCE. Because hurricanes happen every year, there is a constant cycle of damage. There is often not enough money or manpower to inspect every single bridge using complex simulations before the next storm hits. A 2024 U.S. GAO report shows the recovery is still struggling and costs are much higher than expected.
    I'm trying to find a more strategic way to handle this. I've been reading research that suggests Random Forest (a type of machine learning) can be used to "triage" bridges in minutes instead of hours.
    Here is the idea I'm looking at:
    AI Triage: Using a Random Forest model to quickly flag which bridges are at high risk of washing away. This is much faster than doing a full physics simulation (FSI) for every single bridge.
    Smart Construction: Since money is tight for many municipalities, faster and cheaper construction methods could be used for the bridges the AI identifies as high-risk so that local communities don't get hit as hard financially.
    I'm just a student, so I'd really appreciate some help from the engineers here:
    Does this actually sound doable in the real world, or is it too "out there" for agencies like FEMA or a local DOT?
    Are there cheaper bridge designs you've seen work well against coastal waves that a small town could actually afford?
    This hits very close to home for me. I am Puerto Rican and lived on the island from the age of five until 9th grade. I have seen firsthand what happens every year during hurricane season; one of those storms actually destroyed my house. I really want to find a way to help the communities back home stay safe.
    Any advice or direction you can give a future Akron Zip would be awesome!
    Supporting Research & Data:
    https://2021.infrastructurereportcard.org/state-item/puerto-rico/ - 2019 Puerto Rico Infrastructure Report Card
    https://www.sciencedirect.com/science/article/abs/pii/S0141029615004356?via%3Dihub -  Fragility surrogate models for coastal bridges in hurricane prone zones
    https://www.researchgate.net/publication/383691493_Structural_analysis_of_the_economy_of_Puerto_Rico_after_the_elimination_of_Section_936_A_network-based_approach  -   Structural analysis of the economy of Puerto Rico after the elimination of Section 936: A network-based approach
    Puerto Rico Disasters: Progress Made, but the Recovery Continues to Face Challenges
    Mark Gibbs S.M.ASCE
    Student
    Massillon OH
  • 2.  RE: Student question: Using AI to help with bridge recovery for the people of Puerto Rico?
    Posted 01-18-2026 12:03 PM
    Hello Mark,
    Thank you for sharing your story and your research idea-it's inspiring to see such dedication to improving infrastructure safety for your home community. Your AI-based triage concept using Random Forest is very promising. Machine learning models can indeed be used to prioritize inspections and identify high-risk bridges quickly, especially when data is limited. In practice, agencies like FEMA or local DOTs often use risk-based prioritization, so your approach aligns well with current strategies. However, real-world deployment would require sufficient quality and quantity of input data, integration with GIS and inspection databases, and validation against historical bridge failures.
    Regarding bridge designs for coastal resilience, simplified precast or modular concrete structures can often be cost-effective for smaller municipalities. Elevated spans, flexible connections, and optimized pier designs help resist wave forces while keeping costs manageable. Collaboration with local engineering offices can help tailor designs to both budget and hazard level.
    For your project, I recommend:
    1. Start by building a small dataset of local bridges and their damage history.
    2. Test your Random Forest model on this dataset to see if predictions correlate with observed damage.
    3. Explore partnerships with professors or local engineers for guidance and validation.
    4. Document your findings and lessons learned, as this can form part of your portfolio and demonstrate practical applicability.
    Your personal connection to Puerto Rico and understanding of the local challenges will add a valuable perspective to your research. Keep iterating and testing-your idea could make a real impact.
    Best regards,
    Darya Stanskova
    Darya Stanskova M.ASCE
    Fort Myers FL
  • 3.  RE: Student question: Using AI to help with bridge recovery for the people of Puerto Rico?
    Posted 01-19-2026 11:29 AM
    Hello, I want to you thank you for the encouragement and for laying out a roadmap for me! It's great to hear that risk-based prioritization is already being used by agencies like FEMA, and I'm really glad the Random Forest approach aligns with those strategies. I really appreciate the suggestion to into modular designs for smaller municipalities to help balance the budget while staying resilience.
    I'm planning to start building a dataset using NBI records for Puerto Rico to try a small-scale test you recommended. My goal is to use this data to see if machine learning can predict risk in a way that correlates with historical storm damage. To be honest, I am not very good with AI yet, so I would appreciate any advice or resources you might have on setting up the model correctly. I'm moving to the University of Akron soon and hope to find a mentor there to help me refine these ideas and perhaps even test some "hydrodynamic shaping" concepts to reduce wave pressure. Thanks again for the guidance!
    Mark Gibbs S.M.ASCE
    Student
    Massillon OH
  • 4.  RE: Student question: Using AI to help with bridge recovery for the people of Puerto Rico?
    Posted 01-19-2026 11:27 AM
    Dear Mark, your interest in addressing the structural vulnerability of bridges in Puerto Rico reflects both strong technical curiosity and a commendable commitment to public welfare.
    The approach you describe-using machine learning techniques such as Random Forest models to support rapid screening or triage of infrastructure assets-is not only conceptually sound, but also aligned with current research trends in structural health monitoring and risk-informed decision-making. While such methods are not a replacement for detailed physics-based analyses, they are increasingly viewed as valuable tools for prioritization, especially in contexts where time, funding, and manpower are limited.
    In this regard, I would like to point you to the work currently being developed by my colleague Dr. Carlos Arteta (carteta@...), who has been actively implementing and evaluating data-driven methodologies for structural damage identification and assessment. His experience may be particularly useful for you, both in terms of methodological choices and in understanding how these approaches can be realistically integrated with traditional engineering frameworks. I strongly encourage you to reach out to him to discuss possible alternatives and limitations relevant to your specific case.
    The key challenge now is validation, transparency, and demonstrating that these tools can reliably inform-not replace-engineering decisions.
    I wish you every success in your academic path and commend you for pursuing engineering solutions with real societal impact.
    Andres Guzman D.Eng., MEng, Ing., F.ASCE
    Associate Professor
    UNIVERSIDAD DEL NORTE
    Barranquilla
  • 5.  RE: Student question: Using AI to help with bridge recovery for the people of Puerto Rico?
    Posted 01-20-2026 12:58 PM
    Saludos! Dr. Guzman
    I want to thank you for taking the time to review my research and for your encouraging words regarding its potential impact.
    Your point about validation and transparency is well-taken. I agree that these data-driven tools must serve to inform, rather than replace, rigorous engineering judgment. I am currently revising my feasibility assessment to better address how these models can be realistically integrated into traditional frameworks.
    Per your suggestion, I have already reached out to Dr. Carlos Arteta to discuss methodological choices and the limitation of these approaches. I look forward to learning from his expertise in structural damage identification.
    Thank you again for your guidance and for supporting the next generation of Puerto Rican engineers.
    Muchas gracias
    Mark Gibbs
    Mark Gibbs S.M.ASCE
    Student
    Massillon OH
  • 6.  RE: Student question: Using AI to help with bridge recovery for the people of Puerto Rico?
    Posted 01-21-2026 03:53 PM
    Edited by Tirza Austin 01-21-2026 03:52 PM
    Your background parallels mine ( Westchester CC and U of Arizona ). A Long bridge background and might spent money to stop traffic instead of tragic loss of life. Wish I was in warm weather ! Replying from cool NYC .
  • 7.  RE: Student question: Using AI to help with bridge recovery for the people of Puerto Rico?
    Posted 02-02-2026 12:23 PM
    Len,
    It's great to hear from someone with a similar CC background who has spent a career in the field. I'm actually Brooklyn born and did my entire high school there, I went to Locust Valley High.
    Your point about spending money to stop "tragic loss of life" rather than just "traffic" is the exact mission behind my triage model. I am building this AI to ensure that the quiet, high-risk bridges don't get overlooked by the high-traffic urban ones.
    I value that NYC perspective and would love to stay in touch as the research develops. Stay warm up there!
    Mark Gibbs S.M.ASCE
    Student
    Massillon OH
  • 8.  RE: Student question: Using AI to help with bridge recovery for the people of Puerto Rico?
    Posted 01-25-2026 02:10 PM
    Mark – amid some great feedback and suggestions to your research question – here are something more I like to add.
    As you know – Random Forest Model is a statistical tool based on ensemble analysis of large datasets incorporating individual Decision Trees. If not seen already – have a look at the 2024 NASA-NESC Technical Note – Statistical Analysis Using Random Forest Algorithm . . . It's a good source for clarity of understanding and approach.
    On the question of training AI machine to learn the random forest model, and applying it – a NAP publication, the 2024 NAP 27902 Implementing and Leveraging Machine Learning at State DOTs, especially its Chapter 5 – will give you ample insights on AI applications and machine learning catering to DOT activities.
    You may also look at my essays for more and to further your research: Artificial Intelligence – the Tool of No Limit and The World of Numbers and Chances.
    Dr. Dilip K Barua, PhD
    Website Links and Profile
  • 9.  RE: Student question: Using AI to help with bridge recovery for the people of Puerto Rico?
    Posted 02-02-2026 12:22 PM
    Dr. Barua,
    Please accept my apologies for the delayed response; I've had a bit of a rough week and I am just this weekend getting back to my research.
    Thank you for taking the time to provide such a high-level technical roadmap. I haven't had a chance to go through all of the resources you shared yet, but I will be diving into them this week, specifically the NASA-NESC 2024 Technical Note and the NAP 27902 publication.
    Using a Space-Grade statistical approach for bridge safety is exactly the level of rigor I am aiming for. I will reach back out to you later this week with a status update once I've had a chance to fully process these materials.
    Thank you for the guidance.
    Mark Gibbs S.M.ASCE
    Student
    Massillon OH
