The nice thing about religious facilities are that the parking lots are not occupied during all time periods, and that most people do not go to church during flooding events. The bad thing about religious facilities is that they tend to be centers of safety and organization during natural disasters. As I am from the Houston area, I have seen this happen many times. Nothing worst for a parishioner to come into church with a dry car, and have to have it towed when they leave 2-hours later because it has 2 feet of water surrounding it.
I have designed parking lot detention. When I do it, my rule of thumb is that 25% of the parking spaces need to be dry during the 100-year event, another 25% should be dry during the 25 year event, and the rest should not flood more than 9-inches during the 100-year event. This keeps it out of most cars. Lots of inlets are required to ensure that the water does not start accumulating above the surface before the underground system is filled. This prevents the more-than occasional issue of standing water.
Underground systems will collect sediment and debris if you are not careful, and most systems are hard to impossible to remove that sediment/debris. Consider sediment collection in the design of the inlet locations. If available, use an above ground system for the first 1-2 inches of storage, and send the drainage to the above-ground storage system for the small events, and overflow to the below ground systems for the extreme events. That way, most of the items that cause chaos to underground detention systems (plastic cup lids, foam cups, plastic sacs, etc.) get trapped in the above ground pond that can be maintained. I have found a reverse grade storm sewer between the above ground pond and the underground detention works well at keeping the floatables out, while allowing water to flow in. It works even better if you have a wet pond for the above ground part with a large separation between inlets to the pond, and outlet to the underground detention.
There are lots of other things to consider, including what complies with the local regulations. It is always possible to pay for for a system review by an independent engineer that practices in the specific community if you have specific concerns about whether a specific design will meet the needs of the owner. Its no different than a second opinion from a doctor over a treatment process.
Dwayne Culp, Ph.D.
Culp Engineering, LLC
Rosenberg TX
(713)898-1977
