Stanley,
First entry in SQ card should be "zero" not "o".
CC
Chung-Cheng Yen, PhD, PE |Surface Water Group
Main: 949.809.5000 | Fax: 949.809.5003 | Direct: 949.809.5102
chung-cheng.yen@... | www.tetratech.com
Tetra Tech | Complex World, Clear Solutions
17885 Von Karman Avenue, Suite 500, Irvine, CA 92614
PLEASE NOTE: This message, including any attachments, may include privileged, confidential and/or inside information. Any distribution or use of this communication by anyone other than the intended recipient is strictly prohibited and may be unlawful. If you are not the intended recipient, please notify the sender by replying to this message and then delete it from your system.
P Think Green - Not every email needs to be printed
I have a project that I'm trying to reproduce a very old HEC-1 model (Version July 1978 Last Modification 26 Feb 79) to run on a newer HEC-1 model (Version 4.1 Jun 1998). I have coded the data and it runs and reproduces the inflow hydrograph but doesn't route the hydrograph through the dam. I have tried a number of changes and nothing worked, so I have attached the input (OSH2.dat) and output (OSH2.out)files and was wondering if some one could take a quick look and see if you see the problem and let me know the solution.
Any help is greatly appreciated.
Stanley Johnson P.E., L.S., M.ASCE
Chief Engr
Columbus OH
(614) 864-8405
