The purpose of this post was to raise awareness among the members of civil engineering communities – of a problem as important and massive as the New Orleans flood/storm surge protection levee. Indeed, the problem is more complicated than what one could discuss in this forum – not knowing what the actual conditions are. But a major undertaking – becoming ineffective (or less effective on the premise of designed scenarios) in about 4-years time after completion – is not something anyone can swallow easily. Of course, only a test – perhaps the likeness of Hurricane Katrina – can prove or disprove whether or not the assertion is true – but then it would be too late.
Thank you, Bill for pointing out my use of redundancy. I meant ineffectiveness, which is more aligned with Oxford English, but the Webster English and engineering define it as an extra layer of safety exceeding what is necessary. Yes, one should be careful in wording – because linguistic, cultural and technical connotations may not always agree.
While ASLR results from the additive effects of global sea level rise and local subsidence – the variability and predictability of both are understandably not the same (Michael Byle's point). And one weak area or areas of the levee (
weak for whatever reasons – inadequacy of site specific borelog data and assumptions to compensate that, or other flaws) is often sufficient for failure of the entire system in the face of a storm surge/flooding episode like that of Katrina.
Vancouver, BC, Canada
Website:
https://widecanvas.weebly.com------------------------------
Sent: 04-23-2019 04:05
Subject: New Orleans' Levees Sinking after Massive Upgrading
I am wondering about the studies which were conducted for this structure with such high cost. I am with Michael Byle that we should not take from the press what is said about all the factors that cause such failure. Sinking is caused by settlement due to weakness of the subsoil but not due to land subsidence and sea level rise that have a long term effect which we can not observe in this short term. The question now is "does the sinking continue?", As such, I advise to make extensive inspection and monitoring program to identify the locations and causes for this sinking.
Kind Regards,
Ahmed Sayed Mohamed Ahmed, PhD, D. CE., M. ASCE,
Senior Coastal Engineering
Dar Al Handasah (Shair and Partners)
Egypt
