Another problem is that people assume that the worst scour depths occur due to the largest flow conditions. I always teach to do a full range of flows and do the scour computations for each condition. For instance, using HEC-RAS at just bank flow depth may give higher shear stress than for a higher flow condition that has water in the overbanks that re-distributes the total flow and decreases the flow in the main channel.
Another problem could be that a lower flow comes to an elongated pier at a worse flow angle than the higher design flow, resulting in more pier scour than previously thought. If you have a 2-D model, this change in angle could easily checked.
So now I have a total of 9 potential scenarios to present related to mis-application of HEC-RAS for bridge scour analysis. Again, I am open to suggestions for more problems that you can present to me for possible inclusion or substitution to the proposed ones. I give credit for contributions of material to my presentations.
I have taught 2-3 day seminars for ASCE on HEC-RAS (and for FHWA) and Bridge scour analysis but they were separate and not integrated like what I am proposing.
David Williams Ph.D., P.E., D.WRE, F.EWRI, F.ASCE
David T. Williams and Assoc.
Commerce City CO
