Collaborate Home
My Profile
Browse
Discussion Posts
Glossary
Library Entries
Member Home (Admin)
1.5K
24.5K
Back to discussions
Expand all
Collapse all
ANSYS Fluent sofware for Hydraulic Engineers
1.
Like
Ebissa Gadissa
Posted 02-03-2022 10:04 AM
Options Dropdown
Ansys Fluent
is the industry-leading fluid simulation
software
known for its advanced physics modeling capabilities and industry leading accuracy. It contains the broad physical modeling capabilities needed to model flow, turbulence, heat transfer, and reactions for industrial applications ranging from air flow over an aircraft wing to combustion in a furnace, from bubble columns to oil platforms, from blood flow to semiconductor manufacturing, and from clean room design to wastewater treatment plants. Special models that give the software the ability to model in-cylinder combustion, aeroacoustics, turbomachinery, and multiphase systems have served to broaden its reach.
my question is how ''ANSYS Fluent is working to simulate velocity and shear stress distributions based on RANS and 3Dfor open channel flows? can you share with me your experience related to ANSYS fluent software to simulate flow velocity and shear stress in open channel? To check or validate your modeling, Is the simulated result and Analysed solution must be agreed with the experimental data?
Ebissa Gadissa S.M.ASCE
PhD Scholar
Addis Ababa
New Best Answer
This thread already has a best answer. Would you like to mark this message as the new best answer?
Related Content
Modeling unsteady flows in large scale rivers with secondary flows
Ebissa Gadissa
Added 01-15-2023
Discussion Thread
9
Impact of Oceans on Ground Water
Ebissa Gadissa
Added 01-28-2022
Discussion Thread
5
Climate change and Water Resources
Ebissa Gadissa
Added 01-03-2022
Discussion Thread
3
Environmental Impact Assessment and climate change
Ebissa Gadissa
Added 12-27-2021
Discussion Thread
1
Hydraulic Modeling
John Weiland
Added 04-10-2017
Discussion Thread
4
Copyright 2025. All rights reserved.
Community Tags
Add a tag
x
User Tags may not contain the following characters: @ # $ & :
