Some tips on successfully publishing with ASCE based my experience as an author, reviewer, and associate editor:
1. Before writing:
a. Visit the ASCE Author Center for a list of publications, publication types, and guidelines for submission.
b. Be familiar with your journal of choice – note the range of paper topics plus typical paper structure, tone, and audience.
2. Writing the manuscript:
a. Begin with a clear statement of purpose for the manuscript. Keep that purpose in mind as you create the rest of the manuscript. For anything other than a Technical Paper, state the TYPE of contribution (e.g., cases study) in the purpose statement. Explain how the manuscript is significant contribution.
b. Avoid creating multiple new acronyms for the reader to memorize.
c. Use the Conclusions section to show the reader that the manuscript's purpose has been achieved by citing results and discussion from the body text.
d. Write the Abstract last. It should convey the essence of the manuscript, as if the entire text was boiled down to a very concentrated form. For case studies, say so in the abstract, too.
3. Revising the manuscript:
a. Don't respond while upset by reviewers' comments. Most comments are meant to help the author.
b. Respond to reviewer comments by revising the manuscript and telling which line numbers the revision can be found on. A discussion of the comment is unnecessary unless you disagree with the comment.
c. If you disagree with a reviewer's comment and will not change the manuscript on the point in question, explain why in a professional, neutral tone. Use this option only if absolutely necessary.
d. If one reviewer is unreasonably harsh and another is not, you can ask the editor for an alternate reviewer to replace the harsh one if you believe the comments to be unjustified.
ENGINEER
Columbus MS
