Aerospace Engineering
https://doi.org/10.1061/(ASCE)AS.1943-5525.0001323
9/1/2021
10/31/2021
Tolerance Design of Multistage Aero-Engine Casing Assembly by Vibration Characteristic Evaluation
Architectural Engineering
https://doi.org/10.1061/(ASCE)AE.1943-5568.0000484
9/1/2021
11/30/2021
Potentials for Adapting Danish Sustainable Houses to Climate Change: Simulation Study on the Effects of Climate Change in Low-Rise Sustainable Houses
Cold Region Engineering
https://doi.org/10.1061/(ASCE)CR.1943-5495.0000256
9/1/2021
11/30/2021
Thermal Stabilization of Embankments Built on Thaw-Sensitive Permafrost
Construction Engineering & Management
https://doi.org/10.1061/(ASCE)CO.1943-7862.0002132
9/1/2021
9/30/2021
Scan2BIM-NET: Deep Learning Method for Segmentation of Point Clouds for Scan-to-BIM
Environmental Engineering
https://doi.org/10.1061/(ASCE)EE.1943-7870.0001889
9/1/2021
9/30/2021
Benchmarking Reynolds-Averaged Navier–Stokes Turbulence Models for Water Clarification Systems
Geotechnical & Geoenvironmental Engineering
https://doi.org/10.1061/(ASCE)GT.1943-5606.0002585
9/1/2021
9/30/2021
Evaluation of Roundness Parameters in Use for Sand
Hydrologic Engineering
https://doi.org/10.1061/(ASCE)HE.1943-5584.0002119
9/1/2021
9/30/2021
Assessment of the Contributions of Climate Change and Human Activities to Runoff Variation: Case Study in Four Subregions of the Jinsha River Basin, China
Irrigation & Drainage
https://doi.org/10.1061/(ASCE)IR.1943-4774.0001590
9/1/2021
9/30/2021
Experimental Study of the Hydraulic Performance of Continuous Transverse Grates
Journal of Structural Engineering
https://doi.org/10.1061/(ASCE)ST.1943-541X.0003097
9/1/2021
9/30/2021
Earthquake and Postearthquake Fire Testing of a Midrise Cold-Formed Steel-Framed Building. I: Building Response and Physical Damage
Journal of Transportation Engineering, Part A: Systems
https://doi.org/10.1061/JTEPBS.0000553
9/1/2021
9/30/2021
Road Sign Occlusion under Truck Platooning
Management in Engineering
https://doi.org/10.1061/(ASCE)ME.1943-5479.0000958
9/1/2021
10/31/2021
TAB Bid Irregularity: Data-Driven Model and Its Application
Materials in Civil Engineering
https://doi.org/10.1061/(ASCE)MT.1943-5533.0003827
9/1/2021
9/30/2021
Effect of Strain History and Mixture Proportions on Early-Age Cement Paste and Mortar Stress Relaxation
Risk & Uncertainty in Eng Systems
https://ascelibrary.org/doi/10.1061/AJRUA6.0001144
9/1/2021
11/30/2021
Sustainable Building Construction: Tension between Material Efficiency and Earthquake Risk
Urban Planning & Development
https://doi.org/10.1061/(ASCE)UP.1943-5444.0000722
9/1/2021
11/30/2021
Vision and Project to Retrofit the “Urban Dust” Scenario: Simulation in the Region of Umbria, Central Italy
Waterways, Ports, Coastal
https://doi.org/10.1061/(ASCE)WW.1943-5460.0000645
9/1/2021
10/31/2021
Effects of Different Geometric Parameters of Complex Bridge Piers on Maximum Scour Depth: Experimental Study
