ASCE Book Club - Free Papers for June
  • 1.  ASCE Book Club - Free Papers for June
    Posted 06-02-2021 09:11 AM
    ASCE provides a healthy number of free research papers each month. The following is a list of free publications content for the month of June.
    (Note: When you click on the link you will be leaving Collaborate.asce.org and directed to ASCELIBRARY.org where you must re-enter your ASCE login credentials to access the free content. The login button is in the upper-right corner).
    I'll be sharing these papers each month to encourage discussion on some of these topics. I'll also be tagging these posts as "ASCE Papers" for you to easily access in the future. Please feel free to comment on other areas where you might like to see additional research as well!
    June 2021
    Journal
    DOI
    Open
    Close
    Composites for Construction
    https://doi.org/10.1061/(ASCE)CC.1943-5614.0001129
    6/1/2021
    7/31/2021
    Large-Scale FRP-Confined Rectangular RC Columns with Section Curvilinearization under Axial Compression
    Perf. of Constructed Facilities
    https://doi.org/10.1061/(ASCE)CF.1943-5509.0001567
    6/1/2021
    7/31/2021
    Facades of Manhattan Apartment Buildings from the 1902–1915 Period. I: Modes of Failure
    Construction Engineering & Management
    https://doi.org/10.1061/(ASCE)CO.1943-7862.0002056
    6/1/2021
    6/30/2021
    Measuring the Impact of Immersive Virtual Reality on Construction Design Review Applications: Head-Mounted Display versus Desktop Monitor
    Environmental Engineering
    https://doi.org/10.1061/(ASCE)EE.1943-7870.0001872
    6/1/2021
    6/30/2021
    Pilot-Scale Investigation of Floating Treatment Wetlands as Retrofits to Waste-Stabilization Ponds for Efficient Domestic Wastewater Treatment
    Engineering Mechanics
    https://doi.org/10.1061/(ASCE)EM.1943-7889.0001924
    6/1/2021
    6/30/2021
    Simulation of High-Strain-Rate Comminution through a Breakage Model with Adaptive Rate Dependence
    Energy Engineering
    https://doi.org/10.1061/(ASCE)EY.1943-7897.0000761
    6/1/2021
    7/31/2021
    Characterization of Gas Saturation in Tight-Sandstone Reservoirs with Rock-Physics Templates Based on Seismic Q
    Geomechanics
    https://doi.org/10.1061/(ASCE)GM.1943-5622.0002027
    6/1/2021
    6/30/2021
    Correlation of Critical State Strength Properties with Particle Shape and Surface Fractal Dimension of Clinker Ash
    Geotechnical & Geoenvironmental Engineering
    https://doi.org/10.1061/(ASCE)GT.1943-5606.0002509
    6/1/2021
    6/30/2021
    Effects of Bacterial Density on Growth Rate and Characteristics of Microbial-Induced CaCO3 Precipitates: Particle-Scale Experimental Study
    Hydraulic Engineering
    https://doi.org/10.1061/(ASCE)HY.1943-7900.0001873
    6/1/2021
    6/30/2021
    Field Measurements and Numerical Modeling of Hydraulic Transients in HDPE Pipeline with PRV Interaction
    Irrigation & Drainage
    https://doi.org/10.1061/(ASCE)IR.1943-4774.0001559
    6/1/2021
    6/30/2021
    Novel Monitoring System for Detecting Malfunctioning In-Canopy Sprinklers on a Center Pivot Irrigation System
    Infrastructure Systems
    https://doi.org/10.1061/(ASCE)IS.1943-555X.0000606
    6/1/2021
    8/31/2021
    Assessing the System Resilience Trade-Off Space: Empirical Model of the Port of Houston Waterway Recovery Process
    Materials in Civil Engineering
    https://doi.org/10.1061/(ASCE)MT.1943-5533.0003661
    6/1/2021
    6/30/2021
    Reactivity of Recycled Aggregates Used for Pavement Base: From Field to Laboratory
    Risk & Uncertainty in Eng Systems
    https://doi.org/10.1061/AJRUA6.0001107
    6/1/2021
    8/31/2021
    Revised Comparison of Tunnel Collapse Frequencies and Tunnel Failure Probabilities
    Structural Engineering
    https://doi.org/10.1061/(ASCE)ST.1943-541X.0003006
    6/1/2021
    6/30/2021
    Probabilistic Models and Fragility Estimates for Unreinforced Masonry Walls Subject to In-Plane Horizontal Forces
    Transportation Eng: Systems
    https://doi.org/10.1061/JTEPBS.0000498
    6/1/2021
    6/30/2021
    Reflections on the History of the ASCE Journal of Transportation Engineering
    Urban Planning & Development
    https://doi.org/10.1061/(ASCE)UP.1943-5444.0000627
    6/1/2021
    8/31/2021
    Development of Evaluation Model of Urban Growth Stage Considering the Connectivity between Core and Periphery
    Water Resources Planning & Management
    https://doi.org/10.1061/(ASCE)WR.1943-5452.0001369
    6/1/2021
    6/30/2021
    Using Multiobjective Optimization to Inform Green Infrastructure Decisions as Part of Robust Integrated Water Resources Management Plans
    Tirza Austin
    Manager, Online Community
    American Society of Civil Engineers
    1801 Alexander Bell Drive
    Reston, VA 20191
