There are a myriad of factors that seem to play into quality of life/productivity as influenced by commute time. Zoning, land use, education opportunities, crime...the list goes on as it relates to where people live vs. where they work. Since so many of those things are out of the control of a DOT or owner agency, I think DOTs are largely
responsive rather than
responsible for
how their facilities are used. (I do want to be clear that I'm not saying DOTs aren't responsible for their facilities, just that they have little control over how many people decide to use their system, when they use it, where, etc...)
I saw the reports as ways to better understand and define the
usage of a system in order to formulate the best response to an issue, whether that be a planning issue, a maintenance issue, or an operations/safety issue. In my experience (limited...I've only been at this 14 years now), productivity and quality of life aren't vocabulary being used. They may ABSOLUTELY be affected, but traffic operations (congestion, level of service, density, etc), safety, and cost are what show up in pro/con lists of solution alternatives.
I think relating commute time to global competitiveness makes sense. For a personal anecdote, I recently switched offices to a location about half the distance to my home from what I had been commuting. I'm not sure if I
notice a change in productivity, but I do notice a change in quality of life (a bit more sleep in the mornings, a bit more time to help with dinner in the evenings).
Kensey Russell P.E., M.ASCE
Project Manager
HNTB
Kansas City MO
Sent: 03-31-2017 12:13
Subject: Performance-Based Geometric Design - TRB Presentation
Very interesting, although outside of what I have studied. I did not attend TRB, but I do have a question. How does the direction appear to be going now in terms of productivity and quality of life? This is particularly relevant in the global economy. My biggest concern is in the 85th percentile speed (mentioned in both documents), essentially at +1 standard deviation of the average freeflow speed. 1 standard deviation is the inflection point from the "grouped" typical, or concave down, to concave up on the bell curve. Setting the speed limit below that increases speed differentials which is a large cause of accidents. Granted, the higher the speed the more severe the accident, but when traffic "platoons" the number of accidents decreases.
Less commuting time means more time at home with family etc., therefore higher quality of life. It also means higher productivity. This means America is more competitive in the global market. Does that make sense?
Stephen Hemphill P.E., M.ASCE
Semi-Retired
Rio Rancho NM
