Since the advent of geosyntetic fabrics, such as geotextiles and geogrids, use of logs for soil reinforcement has virtually disappeared. Less than 10 years ago I recommended it for an embankment on very soft, swampy soil, using the cut down swamp trees as reinforcement along the border of the embankment. In spite of the careless construction, with logs randomly placed, not orthogonally to the border and tied together as should have been done, only about 20% of the 3-m high, 500-m long reinforced slope failed, proving that somehow the reinforcement worked. But I doubt that even in such cases where logs are available, it is a more economical solution than the geosyntetic one, due to the intense handwork required.
Eduardo Do Val P.E., Ing., M.ASCE
Partner
Do Val Engenharia Consultiva
Sao Paulo
55 11 38133443
