Hi Karen,
We have been able to successfully use ICPR 4 in larger watersheds up to about 5 SM that were both urbanized and undeveloped. Our experience with large urbanized watersheds has found that calibrating the model stability parameters can be challenging if a lot of negligible storage elements are present in the model, such as zero-storage nodes representing drainage manholes and catch basins. However, the challenge is not insurmountable.
If you are able to generate a high-quality DEM to import into the project, then the stage-area and cross-section takeoff tools can save a lot of time in the model development stage.
Cameron Houmann P.E.
Senior Registered Engineer
Donald W. McIntosh Associates, Inc.
Winter Park, FL
Cameron Houmann P.E., M.ASCE
Project Engineer
Altamonte Springs FL
