  • 1.  Rooftop Dog Park Runoff
    Posted 07-30-2018 05:36 PM
    Edited by Tirza Austin 07-30-2018 05:35 PM
    We're starting to see plans calling for AstroTurf rooftop dog parks and are running into a bit of a conundrum when it comes to treating this runoff.  This particular example is going on the 6th floor of a new development building and runoff is designed to be directed into roof drains (as per the norm for buildings). We are skeptical about this going into the sanitary system because it would contain large amounts of rain water, the pipe is only a 12-inch and we don't want to overwhelm the system.  We don't really want that running into the storm system untreated either.  Technically, ground level dog parks aren't treated either (but they do get some overland flow/natural ground cover treatment).
    Has anyone run into this kind of issue before or have any ideas of where we can look for a solution?
    Sara DeGroot ENV SP, P.E., M.ASCE
    CIVIL ENGINEER III
    Alexandria VA
  • 2.  RE: Rooftop Dog Park Runoff
    Posted 07-31-2018 02:01 PM
    Edited by Tirza Austin 07-31-2018 02:01 PM
    Sara,
    This is a unique problem, but one that we've run into before.  You're right that many dog parks on ground level have area drains that go directly to storm.  Whether you're allowed to go to storm versus sanitary is likely going to be dependent on the location of the project.  If a city has a combined storm/sanitary system, they may not care too much either way.  Regardless, I would recommend looking at a natural systems approach.  This could be ground cover treatment/swales like you mentioned, coupled with a stormwater wetland. This would help address both the water quality and quantity by reducing the peak flow and removing nutrients.  Of course, this would require a bit of dedicated area which may or may not be available for your project.  Best of luck.
    Justin Lyon P.E., LEED AP, M.ASCE
    Biohabitats
    Philadelphia PA
    (973)262-1819
  • 3.  RE: Rooftop Dog Park Runoff
    Posted 07-31-2018 04:22 PM
    Justin,
    Have you done a natural systems approach on a rooftop?  Like a different type of green roof coupled with the dog park?
    CIVIL ENGINEER III
    Alexandria VA
  • 4.  RE: Rooftop Dog Park Runoff
    Posted 07-31-2018 02:02 PM
    Haven't run into this situation but it sounds like the perfect fit for a stormwater detention tank at ground level perhaps with a septic tank on the outlet end or built in to the detention tank. The septic part could be connected to the Sanitary Sewer system.
    James Anderson, MASCE
    Anderson Consulting
    North Richland Hills, TX
    817-946-9943
    James
  • 5.  RE: Rooftop Dog Park Runoff
    Edited by Tirza Austin 07-31-2018 04:21 PM
    James,
    Interesting idea.  We don't normally allow septic tanks in the city (we're a very urban city with sanitary sewer system available throughout the city for all development to connect to) so this isn't something we had thought of.  We'll have to look into this some more.
    CIVIL ENGINEER III
    Alexandria VA
  • 6.  RE: Rooftop Dog Park Runoff
    Posted 08-01-2018 10:05 AM
    Edited by Tirza Austin 08-01-2018 10:05 AM
    Similar to the prior idea, you could have a roof drain that goes to a ground-level biofiltration chamber, like a tree box filter or other similar device.  After some amount of ground-level treatment it can discharge to the storm drain.  Also, on the roof, suggest some additional physical barriers close to the drain blocking larger material from dropping into it.
    Saul Nuccitelli P.E., M.ASCE
    Chief Hydraulics Engineer
    Texas Department of Transportation
    Austin TX
    (512)416-2219
  • 7.  RE: Rooftop Dog Park Runoff
    Posted 08-01-2018 11:58 AM
    Edited by Tirza Austin 08-01-2018 11:58 AM
    While I'm unsure of your local regulations, some jurisdictions view stormwater differently depending on source. For example, in Washington State, runoff from vehicle space and chemically-treated landscaping is viewed as pollution-generating, which requires water quality treatment in addition to flow control; whereas runoff from other hard surfaces (e.g., rooftops) is considered non-pollution generating and requires only flow control.
    Given the rooftop use as a dog park, that space would fall into the pollution-generating category, requiring water quality treatment.  Perhaps you could do something like a "modular wetland", sand filter, or similar.  And of course, source control in the form of signage, public outreach to tenants, and bag dispensers and trash receptacles couldn't hurt.
    Eric Pilcher P.E., M.ASCE
    Bonney Lake, WA
    eric.pilcher@...
