In my opinion, if I am not making occasional mistakes,I am stagnating and failing to advance my skills.
I try to think of "mistakes" in three categories.
The first is "informed decisions" that don't work out. In one sense, those really aren't mistakes. A decision is made to use an approach that offers a reasonable chance of working. But sometimes the approach doesn't work. That really isn't a mistake, but it does become a mistake if the risk that it might not work hasn't been adequately or effectively conveyed to decision-makers. The key issue with these types of "mistakes" is being sure that we have adequately and appropriately communicated risks as well as benefits. We especially need to be sure that decision-makers have grasped the risks. Too many of them obsess on the upside and discount the downside, until the downside bites them.
The other two categories or mistakes of omission and mistakes of commission. Mistakes of omission are the failure to consider something that should have been considered. To take a contemporary example, let's say that an emergency spillway is designed for a dam, and a hydraulic design for the spillway is prepared that will handle the defined maximum event. But the design process fails to consider whether that release will cause downstream erosion that will undermine the spillway structure.
Mistakes of commission are where I simply make an error in method or calculation.
As professionals, we need to be sure that we have systematic procedures not only to identify mistakes of commission, but mistakes of omission. During my career I have had the good fortune of being introduced to the failure analysis methodologies
Stephen Nelson P.E., M.ASCE
Consultant
Coal Creek Envtl Assoc
Bellevue WA
(425) 746-7509
Sent: 02-09-2017 11:52
Subject: Re: Engineering Ethics. Case Study 1
Be careful in assigning calculation review to a newer engineer. More experienced engineers can make mistakes and the jr. engineers may not have the experience yet to notice when something's off. I had a situation in my office where one jr. engineer was assigned calculations to design a pumping system that could potentially discharge to one of two points: one was a free discharge and the other was into a pressurized pipeline. A second jr. engineer checked the calculations and they were mathematically correct, but when I reviewed the calculations as a final check, I noted that there was no provision in the calculations to account for the pressure at the second discharge point. So, just saying that even though things may be mathematically correct, does NOT mean they are correct from a common sense standpoint. Needless to say, I then showed the jr. engineers what was missing and had them add the missing information into the calculations.
I have been working for 17 years and still make occasional mistakes. You want all calculations and deliverables to be checked, but the final checks should be by someone who knows what they are doing and is responsible for the work.
Angela Hintz P.E., M.ASCE
Senior Environmental Engineer
Buffalo NY
