One question …
Are you more interested in Q (volume) or q (peak discharge)?
To follow on to Pete’s discussion. Q for CN=65 with 10.64” of P = 6.12” or about 57% of P.
Assuming an AMC III at the start of the storm, CN goes up to 82. Q for CN=82 with 10.64” of P = 8.78 inches or about 83% of P.
Runoff volume will certainly affect peak discharge, but more of the effect on peak is probably seen in the rainfall distribution, the unit hydrograph, and the Tc used in the model.
With the largest volume increments towards the middle to end of the storm, the system is essentially primed before the heavy rains arrive and we can expect larger qs than if the heavy rain occurred during the beginning of the storm.
All of these parts have to play together to get the whole picture.
Are there gages to do some comparison? I’m guessing not, but it would certainly be helpful to have something to calibrate to. High water marks might be a potential.
Claudia Hoeft P.E., F.ASCE
Nat'l Hydraulic Engr
USDA - NRCS
Washington DC
Sent: 03-31-2017 16:05
Subject: Please provide your opinion about CN values for VERY LARGE RAINFALL events
Mike
I agree with Bill… even not knowing the details, like how much runoff (Q) was there?
May not have had the lead-in Complacent limb, but surely approaching Violent response. That is 1:1 with dQ/dP
At the VERY large event we don’t have much experience. Expectations are that it’s a different game. Well past the curvy part of the CN’s P:Q plot.
Plus, if an instrumented research installation encounters one, it often blows out the site and leaves no record.
Assuming that it‘s a Curve Number world out there….The 65 CN doesn’t look impossible as a start-of-storm CN. depending on the site, but the rain surely way beyond experience limits.
Averaging the 2 rainfalls comes to about 13 inches. On a CN(20) of 65, that gives P/S=2.4 . which is well into the development of runoff processes.
Don’t know if it’s useful perspective, but in the 46 years of record at Coshocton ws 26020, [with cn=70] the biggest P/S they ever got was 1.1.
Continuing with the CN belief system, the CN 65 and 13 inches of rain gives a contributing area fraction (dQ/dP) of about 90%.
All above assumes Ia/S=0.20
This is also a problem that comes up in PMFs for spillways: P= mean + 15 standard deviations! Really big storms.
Also, there may be as much uncertainty with the hydrographing in the model as with the CNs? In my thoughts they’re as suspect as the CNs. What model was being used?
Hope this was of some help. Let me/us know how it comes out.
RHH
Richard Hawkins Ph.D., P.E., F.EWRI, F.ASCE
Professor Emeritus
Tucson AZ
Sent: 03-31-2017 15:50
Hi Mike and all,
I took a quick look at an 8000 acre region in Lexington/Richland County just below Columbia with Web Soil Survey. There appear to be many A/B soils with some significant C/D soils in the region. Slopes were zero to 2% for the most part. Available (0 to 60 inch) storage ran about 10 inches (the major block of Congaree loam of 2000 acres). Part of this storage was no doubt filled before the event began. The layer K value was roughly 22 inches per day with lots of other higher values. I don’t know the situation below 60 inches but it is probably much less permeable.
With the series of rainfalls you outlined, I don’t believe you experienced complacent/violent behavior but I would speculate that you were losing storage S as the event unfolded. This would in effect result in increasing CN values as you are thinking.
This could be at least a significant footnote for the ongoing revision. Thanks for sharing this.
Ernest Tollner P.E., M.ASCE
Professor
University of Georgia
Athens GA
