I perceive slow implementation to be related to the balance between regulations, cost, and familiarity. If there are no regulatory requirements or very clear cost savings that prompt its use, then engineers, developers, and municipalities/DOTs are not incentivized to innovate, as you mentioned. Also, I think generally municipalities are more cautious to experiment, unless the feds or DOTs have already clearly signed off and used certain pavements. Municipalities also have crews trained in certain kinds of maintenance and changing gears on the O&M side is costly/difficult. In Texas, we have heard of fairly significant installation issues for permeable concrete related to achieving uniformity, perhaps that speaks to contractor familiarity/experience. I think it also comes down to "why change?" and if the water quality, safety/visibility (wet tire spray), or other benefits are not perceived to be greater than the costs and difficulties, then inertia will continue.
Saul Nuccitelli P.E., CFM, M.ASCE
City of Austin, Watershed Protection Department
Austin TX
