First, about gravel roads. Gravel roads generally are paved with a broad mix of gravel sizes to encourage the aggregate to lock together and spread load. Most bases use a small amount of dust or choke to assist this process. In Ohio we generally use a material from the Ohio Department of Transportation specified as 304 Aggregate Base. It is meant to exclude water from penetrating the aggregate because a high moisture content causes the subbase to emulsify when loaded or when frozen.
The curve number for railroads is unrelated to gravel roads. Railroad base consists of large, broken or angular aggregate that is designed to lock together and spread the load of a train on the rails. It is highly pervious. However, the subbase for a railroad has been compacted and usually graded to prevent penetration of water and to drain the water from under the railroad. A reasonable estimate for a curve number under the base would be a compacted (or remolded) soil with no vegetation.
Use the in situ soil (on either side of the railroad) with bare earth and bump the hydrologic soil on level to compensate for remolding the soil. One of the appendices in TR55 explains the reasoning behind this for construction sites.
I think you will find that in most cases, you can use the curve number for a gravel road as a substitute. If you are in the western states, you might have Hydrologic Group A or B soils which might give you some benefit in reducing the runoff load, but generally not in Ohio.
https://www.codot.gov/programs/research/pdfs/2012/runoff.pdf is a paper that studied the rational runoff coefficient "C" for railroad ballast. One conclusion was that railroad ballast is designed to remove runoff water quickly and the observed runoff coefficient was higher than generally assumed.
Enjoy!
Casey Elliott, PE, PS
London OH
