William,
You have raised an important and timely point that aligns closely with the ongoing efforts within ACOPNE. The Body of Knowledge (BoK) for Navigation Engineering is currently being updated to ensure it fully encompasses the technical breadth and interdisciplinary competencies expected of a board‑certified Navigation Engineer. The material you shared reflects several key elements and will be effectively integrated into the expanded and more detailed framework under development.
Thank you as well for your continued contribution to shaping the Navigation Engineering BoK. Your outline provides valuable structure, and the points highlighted by Dilip Barua-particularly regarding floating structure stability, navigation aids, and navigation‑related communication systems-address critical intersections with mechanical and electrical engineering that are fundamental to safe and efficient navigation.
In addition to these areas, the updated BoK will incorporate several other essential domains, including:
1. Engineering Economics and Decision‑Making
Navigation Engineers must understand cost–benefit analysis, lifecycle cost assessments, and economic optimization to support effective planning, investment, and prioritization of waterway and navigational infrastructure projects.
2. Numerical and Physical Modeling
Given the increasing reliance on advanced analytical tools, proficiency in both numerical and physical modeling is essential. This includes:
- Fast‑time navigation simulations
- Real‑time navigation simulations
- Hydrodynamic, sediment transport, and morphodynamic modeling
- Physical modeling for channel hydraulics, vessel interactions, and structural performance
3. Navigation System Design and Analysis
This includes understanding design criteria for waterways, channel geometry, under‑keel clearance, maneuverability requirements, traffic management, and comprehensive navigational risk assessment.
4. Integrated Waterway and Port Systems Understanding
Although ACOPNE administers a separate Port Engineering certification, the Navigation Engineering BoK will maintain a strong focus on navigation‑specific elements rather than land‑side port planning and berth structural design. However, Navigation Engineers must still understand how channels interface with turning basins, approach channels, pilotage areas, and terminal access zones.
5. Regulatory, Environmental, and Operational Considerations
Navigation Engineers should be familiar with:
- Environmental compliance and permitting requirements
- Local, national, and international navigation regulations
- Operational constraints associated with vessel traffic, tides, sedimentation, and maintenance cycles
6. Dredging Engineering and Sediment Management
A crucial component of navigation engineering is the ability to plan, manage, and monitor seabed dredging operations to ensure adequate navigable water depth.
The BoK will address:
- Determination of required channel depths, widths, and side slopes based on vessel characteristics
- Evaluation of seabed materials and sediment behavior
- Development of dredging strategies, including capital dredging and maintenance dredging
- Management of dredged material, including:
- Proper handling and disposal of unsuitable material at approved offshore or onshore disposal sites
- Identification and stockpiling of suitable dredged material for beneficial reuse, such as land reclamation, beach nourishment, dune stabilization, and habitat restoration
- Environmental impact assessment and mitigation related to turbidity, sediment dispersion, and marine life
- Quality assurance and compliance monitoring during dredging operations
This domain ensures that Navigation Engineers are equipped to maintain safe water depths, optimize material use, and adhere to environmental and regulatory requirements.
Collectively, these expanded elements establish a comprehensive, modernized Body of Knowledge designed to support the technical expertise, interdisciplinary awareness, and professional judgment expected of a board‑certified Navigation Engineer.
Ahmed Ahmed Ph.D., C.Eng, BC.CE, F.ASCE
Associate Principal Coastal Engineer
Dar Al Handasah (Shair and Partners)
Giza
