It is nice reading the interesting discussions contributed by ASM Ahmed, JF Chapman and D Sherman. As some of you are aware, preventative mitigation measures such as configuring, sizing or modification of bays or embayments are indeed done in small scales. For example, harbors for marina and ship berthing are usually sized to avoid resonant amplifications of waves in the infragravity range – and are configured with the help of breakwaters and dampers to diffract waves in such a way that shadowed tranquil areas are maximized, and the exposed illuminated areas and undue reflections are eliminated or minimized.
However, any such modifications to mitigate the effects of large-scale events like tsunami or storm surge can be very overwhelming and challenging (perhaps and I hope that some cutting-edge research is going on somewhere) – in part because such long-period waves would tend not to see or feel the effects of some known engineering measures – to deter them from causing havoc (or having only marginal deterring effect). We have seen how the stone-wall tsunami barrier failed in Japan during the 2011 tsunami. I invite interested readers to have a look at some pieces in my website – the Science & Technology has a piece on Tsunami and Tsunami Forces.
The issues related to Coastal Zone Management (CZM) such as managing the developments in vulnerable coastal areas do need attention – in particular due to the new realities of accelerated sea level rise, probable enhanced storminess in coming years, etc. All coastal countries have CZM bodies to account for such planning issues – one can argue however – whether or not, and to what extent – the plans and policies are bearing the fruit or would do so (in case not done carefully and meticulously), in ensuring the soundness and location of coastal infrastructure, or in benefiting people living in the coastal zone. Some countries are studying the possible effectiveness of extensive buffer zones of mangrove fields or something similar – in absorbing the onslaught energies of tsunami and storm surge.
Vancouver, BC, Canada
Website:
https://widecanvas.weebly.com------------------------------
Sent: 10-09-2018 05:59
Subject: Lesson from Palu Indonesia Tsunami
One cost effective solution is to avoid high density use buildings near the shoreline. It is a question of land use and zoning. For example, residential buildings could only be built at the 5 meter contour. Unfortunately, this is normally not the case as a result human and property losses are high. Having this requirement would also reduce damages from storm surges.
Derek Sherman P.E., M.ASCE
International Infrastructure Consultant
Mitchellville, MD
Sent: 10-07-2018 18:49
Regarding amplification of earthquake generated waves in bays of certain shape & hydrographic conditions, where earthquakes occur, and cities or other developments are located in potentially hazardous locations, maybe in some cases it might prove feasible to make certain modifications to bottoms & sides to reduce the potential effects., and if not, to restrict certain types of developments.
John Chapman P.E., M.ASCE
Environmental Engrg
Eagle River AK
Sent: 10-03-2018 03:58
Thanks Dilip for sharing your thoughts about the recent tsunami at Palu Bay.
We need to learn from this tragedy event using any available documents, the mechanism of forming tsunami due to land-based earthquake and how it is propagated leading to the amplified run up at the head of the bay.
Based on the problem diagnosis, I think a certain mitigation measure may be constructed to change the natural frequency of this bay.
Ahmed Ahmed C.Eng, D.CE, M.ASCE
Senior Coastal Engineer
Dar Al Handasah (Shair and Partners)
Giza
