This may be an example of LID with no benefit, or maybe the only benefit being LEED points or the parkland equivalent. Notice the large gravel beneath the walkway pavement - there is no benefit of porous asphalt on this narrow section when there is plenty of infiltration surface available beneath the asphalt and any water running off the asphalt would reach it easily. The nearby traditional asphalt, in a thicker section with a sealer applied, was undamaged, although not in as apparent a flow path.
William Forbes MASCE, PE, ME, BCEE
Senior Principal Engineer/Vice President of Engineering
Forensic Analysis & Engineering Corporation
Virginia Beach, Virginia
Sent: 07-26-2019 14:39
Subject: Flash flooding
I believe to "anchor" the pavement, additional reinforcing in the pavement section is required or it would tear apart from the forces overtopping the pavement, making it cost prohibitive. In my experience, where there are overtopping flows with high velocities, asphalt does not hold up. Perhaps the use of a streambank reinforcement as a foundation (e.g. modular concrete blocks) would withstand the forces better and maintenance would be limited to the replacement of the sacrificial layer (e.g. aggregate, sand, etc.). The structure should be able to remain as a LID BMP.
John Wood P.E.,M.ASCE
Project Engineer
Pittsburgh PA
