Dear Shivshant Tripathi:
I think that you are asking the wrong question. Before you ask us what job opportunities are available, you need to ask yourself what you want to do.
Do you want to do calculations?
Do you wish to interact with clients?
Do you wish to be an individual working on a project or would you rather be part of a big team?
Do you want to spend time in the field, or would you prefer to spend most of your time in the office.
I am sure that there are a whole lot of other questions that you could ask.
These are the questions that will lead to the answer to most of your questions.
Wastewater engineering includes:
Plant design - for this you will probably be part of a big team, and you will interact with people a lot. Your part on the first few projects will be small.
Plant operation - for this you will be part of a big team, you will generally work for an agency, and you will not communicate often outside your team.
System design/rehab - for this you will be part of a small team. There will be lots of opportunities to get to know your clients, and get to know how to market, and who to market to. This one also could send you down the land development route if you want to expand your role a bit. This could be work all over the developing world.
System operation/maintenance - lots of outside work here, you will be responsible to construct/reconstruct systems, and work a lot with contractors. With ageing infrastructure around the world, there is lots of work here.
This does not even include the whole rest of the environmental engineering fields of storm water, water reuse, water reduction, and the associated plants and distribution systems which also often fall under the management of a wastewater engineering degree.
Good Luck.
Dwayne Culp, Ph.D., P.E., P.Eng, M.ASCE
Culp Engineering, LLC
Richmond TX
