Stuart,
You're right, I didn't make clear my objections to auto-centric development. I erred in favor of brevity, figuring that the harmful consequences are well known. Maybe they are not. This probably isn't the appropriate venue for an exhaustive discussion, but I can make some brief remarks. I would place most negative consequences in one or more of these broad categories. Many could be in all of them.
Public health and safety
Economy
Equity
Social structures and culture
Aesthetics
Ecology/environment
Liberty/choice/quality-of-life
I won't bore anyone with a list, but I'm sure you could come up with several to fit each category.
I don't mean to be a pedant, but I didn't suggest that we let
all highways crumble. Rather, I believe that we should be reducing capacity rather than increasing it, thereby decreasing our collective burden, both economic and otherwise. There are many constructive ways that discretionary or elective trips on highways could be discouraged to allow the remaining capacity to better serve freight and more necessary highway travel.
And, though I certainly wouldn't mind if three quarters of our country's highways disappeared overnight, removing them will be a gradual process. We didn't build the highway system overnight, and we won't tear it down that way. At any rate, removing highways to reduce future costs &c seems like a much better use of limited resources than building new highways and increasing future costs. I believe that, by and large, we're a clever lot. I'm sure we can come up with a better model than what we've been building since private cars were established as the default travel mode. That's a rather low bar, after all.
I certainly don't believe public transportation and travel exclusively by river frame the limits of alternatives to the current model.
At any rate, I appreciate your engagement with me. Thank you.
John:
Transportation is only the most obvious case of our previous development model showing its age. I'm intrigued by the example you cited in Columbia.
I'm not sure the decision will really be up to voters in the end, but maybe you're right.
Tel Jensen S.M.ASCE
Woodland WA
Sent: 03-19-2017 19:36
Subject: ASCE Report Card on America's Infrastructure
Mr. Jensen, you don't make clear why you deem auto-centric development as "harmful." I presume you are concerned about environmental impacts and/or ongoing costs of maintenance, certainly valid interests surrounding sustainability. The problem is complicated by the fact that being "auto-centric" is part of the system of modern life. Our housing, our workplaces, our retail and entertainment facilities are all connected by automotive transportation, so failing to maintain the system of connectedness would lead to a breakdown of life patterns. Depending on what you view as superior to the current system, any rigorous examination will reveal the major challenges to a wholesale change. Public transportation is a good system for some, and is both more economical and environmentally sustaining (Per capita) than automobiles, but is not available equally to all citizens and is not flexible enough to fulfill all needs. At the other end of the spectrum, we could return to river travel as in the 1800's, but the same challenges of availability and flexibility exist. In the jungles of Nicaragua, it is practiced, but the pace of life is so slow that agriculture is virtually the only sustainable lifestyle, and the consequences of heavy traffic on water quality is at least as detrimental as the challenges of air pollution from autos.
It is admirable to think about ways to wean society from its auto-centric ways, but depends on a viable alternative that can be implemented incrementally. I don't believe that allowing highways to crumble will get us where you would like us to go. There are always better ideas, but lots of details have to be worked through.
Stuart Moring P.E., F.ASCE
Dir Of Pub Wrks
Roswell GA
