Region 71
Expand all | Collapse all
Defining SFRS to correctly select the seismic response coefficient
  • 1.  Defining SFRS to correctly select the seismic response coefficient
    Posted 06-13-2025 03:36 PM
    I am designing steel pipe piles, for a site classified as SDC 'C', to support premanufactured electrical equipment cabinets.  I am only designing the foundations.
    The manufacturer of the cabinet does not provide any loading information other than the cabinet weight. They do not provide any information on the construction of the cabinet either.
    In order to determine the loads to be resisted by the piles, I need to determine the SFRS of the cabinets so that I can select the appropriate seismic response coefficient for calculating the seismic loads.
    Based on ASCE 7-16 Section 13.1.5, these should be considered nonbuilding structures similar to buildings so Table 15.4-1. But I don't know anything about the frame or bracing of the cabinet.  So, I use Table 12.2-1 SFRS type H and R = 3.0.
    I calculate the loads and then model the equipment, on the piles, in soil, in a 3D FEA program and limit the deflection at the pile head.
    However, this 3rd party reviewer says that because of the piles, the SFRS should be classified as a cantilever column system or an inverted pendulum, corresponding to an R-value of 2.0 or 2.5 depending on how you classify the system, which I disagree with.
    So, the big questions are:
    Do the deep foundations change the SFRS of the equipment being supported?
    Should the foundation elements effect the SFRS of the equipment?
    Shouldn't the SFRS be specifically for the equipment being supported and not the foundation?
    Mae Benvenga P.E., P.Eng, M.ASCE
    Daily Engineering Consultant, LLC
    Fort Collins CO
  • 2.  RE: Defining SFRS to correctly select the seismic response coefficient
    Posted 06-14-2025 12:24 PM
    Hi @Mae Benvenga
    ASCE hosts a Standards Exchange forum. You are welcome to post this question there as well. Peer-to-Peer Standards Exchange
    Tirza Austin
    Senior Manager, Online Community
    American Society of Civil Engineers
    1801 Alexander Bell Drive
    Reston, VA 20191
