We have been using Bluebeam for the last 5 years, and it works well. They changed the interface in 2020, which makes things a little more difficult than previously, and has me using keyboard commands for some of the common tasks like lines and text. I like it because it has a better printer connection to autocad than adobe does. It takes a little longer than hand markups, but we have a record of our markups, and markup history. Bluebeam supports their products for about 3 years, but I did not have to upgrade the product until my 2015 version stopped saving files.
Generally we print things on a sheet by sheet basis so that we can markup one sheet at a time, and keep the file sizes smaller. Surveys tend to be the biggest files. It also allows multiple different cadd people to work on the sheet set together. We use Jacobs style markup, with multiple colors of text to indicate whether something is a comment that needs to be entered directly (red) a comment that requires the design team to do something else, like update the spreadsheets (blue) or is correct (yellow highlight). Drafters or designers highlight over the comment using green if they addressed it, or red if we need to discuss it before they address it. We have folders called sealed, review, and corrected under each dated review folder. As I comment on things, files get moved to the sealed folder if they do not have comments, review folder if they have comments. Once a cadd person corrects the comments, they move the reviewed file to the corrected folder, and plot a new sheet to the main folder. When all the comments are back-checked, there should be a good version in the sealed folder, and nothing in either the review folder or main folder.
I need to state that I am an internet company, so hand markups are not an option. Back when I worked at Jacobs, I never had enough pens and highlighters of the correct colors, so Bluebeam has saved me from that problem too.
Dwayne Culp, Ph.D., Ph.D., P.E., M.ASCE
Culp Engineering, LLC
Rosenberg TX
