Journal Name
URL
Date Open
Date Close
Title
Journal of Aerospace Engineering
https://doi.org/10.1061/(ASCE)AS.1943-5525.0001490
11/1/2022
12/31/2022
Composite Adaptive Control and Identification of MIMO Aeroelastic System with Enhanced Parameter Excitation
Journal of Bridge Engineering
https://doi.org/10.1061/(ASCE)BE.1943-5592.0001962
11/1/2022
11/30/2022
Quasi-Static Cyclic Testing of Hybrid Posttensioned Bridge Column Supported on a Monopile Foundation
Journal of Construction Engineering and Management
https://doi.org/10.1061/(ASCE)CO.1943-7862.0002353
11/1/2022
11/30/2022
Rapid 3D Quality Control in Prefabrication Using a 3D Digital-Templates Framework
Journal of Engineering Mechanics
https://doi.org/10.1061/(ASCE)EM.1943-7889.0002153
11/1/2022
11/30/2022
A Perspective on Darcy's Law across the Scales: From Physical Foundations to Particulate Mechanics
Journal of Environmental Engineering
https://doi.org/10.1061/(ASCE)EE.1943-7870.0002066
11/1/2022
11/30/2022
Effectiveness of Photocatalysis, Radiolysis, and Ultrasonic Irradiation in the Remediation of GenX: Computational Study of the Ultrasonically Induced Mineralization
Journal of Geotechnical and Geoenvironmental Engineering
https://doi.org/10.1061/(ASCE)GT.1943-5606.0002872
11/1/2022
11/30/2022
Geotechnical Visualization and Three-Dimensional Geostatistics Modeling of Highly Variable Soils of a Hydraulic Fill Dam
Journal of Irrigation and Drainage Engineering
https://doi.org/10.1061/(ASCE)IR.1943-4774.0001718
11/1/2022
11/30/2022
An Explicit Equation for the Maximum Water Application Depth in Center Pivot Irrigation
Journal of Management in Engineering
https://doi.org/10.1061/(ASCE)ME.1943-5479.0001087
11/1/2022
12/31/2022
Use of LinkedIn Data and Machine Learning to Analyze Gender Differences in Construction Career Paths
Journal of Materials in Civil Engineering
https://doi.org/10.1061/(ASCE)MT.1943-5533.0004478
11/1/2022
11/30/2022
Production of Self-Healing Concrete by Bacillus subtilis Spores Immobilized on Sand Using Gum Arabic as an Adhesion Material: Proof of Concept
Journal of Pipeline Systems Engineering and Practice
https://doi.org/10.1061/(ASCE)PS.1949-1204.0000661
11/1/2022
1/31/2023
Onshore Buried Steel Fuel Pipelines at Fault Crossings: A Review of Critical Analysis and Design Aspect
Journal of Structural Engineering
https://doi.org/10.1061/(ASCE)ST.1943-541X.0003459
11/1/2022
11/30/2022
Experimental and Numerical Studies on Fe–Mn–Si Alloy Dampers for Enhanced Low-Cycle Fatigue Resistance
Journal of Surveying Engineering
https://doi.org/10.1061/(ASCE)SU.1943-5428.0000403
11/1/2022
1/31/2023
Statistical Comparison on Accuracies of Web-Based Online PPP Services
Journal of Sustainable Water in the Built Environment
https://doi.org/10.1061/JSWBAY.0000994
11/1/2022
1/31/2023
Utilizing In Situ Ultraviolet-Visual Spectroscopy to Measure Nutrients and Sediment Concentrations in Stormwater Runoff
Journal of Transportation Engineering, Part A: Systems
https://doi.org/10.1061/JTEPBS.0000734
11/1/2022
11/30/2022
Reliability of Vehicle-to-Micromobility Safety Communication
Journal of Water Resources Planning and Management
https://doi.org/10.1061/(ASCE)WR.1943-5452.0001620
11/1/2022
11/30/2022
Effects of Permanent and Temporary Water-Right Payments on Balancing Agricultural and Ecological Interests: A Case Study of Hami Prefecture in Northwestern China
Journal of Waterway, Port, Coastal, and Ocean Engineering
https://doi.org/10.1061/(ASCE)WW.1943-5460.0000723
11/1/2022
12/31/2022
Nearshore Vertical Pore Pressure Gradients and Onshore Sediment Transport under Tropical Storm Forcing
Practice Periodical on Structural Design and Construction
https://doi.org/10.1061/(ASCE)SC.1943-5576.0000730
11/1/2022
1/31/2023
Effects of Vibrations on Structures: Overview and Case Studies
