Most likely you do not have a PERFORM ANALYSIS command after the load cases or combinations and before the FINISH as shown below....
LOADING 2 WIND FROM LEFT
MEMBER LOAD
1 2 UNI GX 0.6 ; 8 TO 10 UNI Y -1.
LOAD COMB 3 75 PERCENT DL LL WL
1 0.75 2 0.75
PERFORM ANALYSIS
FINISH
You may use the command editor to add the command before finish. You may add it using the GUI as well as explained next
In STAAD.Pro Connect Edition : Use the menu option Analysis and Design > Analysis Commands
In STAAD.Pro v8i : Use the Analysis/Print page on the left inside the Modeling mode.
Abdulkareem Jamiu S.M.ASCE
Project Manager
TOTALMARK GLOBAL LIMITED
Ilorin
234234 8169182403
