Reinforcement detailing at the bottom of retaining walls and in knee-joints (a beam-column joint where both beam and column terminate at the joint) is still a subject of discussion among researchers. A famous study by Nilsson and <g class="gr_ gr_52 gr-alert gr_spell gr_inline_cards gr_run_anim ContextualSpelling ins-del multiReplace" id="52" data-gr-id="52">Losberg</g> in 1976 [1] demonstrated the proper orientation of reinforcing bars in such joints. Figures (a) and (b) from Darwin et al. (2016) [2] after Nilsson and Losberg (1976) [1] below show two different reinforcement configurations at the joint. The joint on the left (Figure a) can reach only 24-40% of the nominal flexural strength of the connecting members, while the joint on the right (Figure b) can reach 82-110% of the nominal flexural strength of the connecting members. The efficiency of each joint depended on the reinforcement ratio.
Bar bent inward (Figure b) performs better because it is continuously either in tension or in compression when the joint is subjected to bending moment, as shown in Figures (c) and (d). This is, however, not the case in Figure (a); the hooked bar bent outward is in tension (or in compression) at the outer face of the flange and is in compression (or in tension) at the outer face of the web (Figures c and d). Such alternate compression and tension stresses along the same bar makes it ineffective in arresting cracks resulting in reduced joint efficiency.
An additional bar placed diagonally from the outer face of the flange to the outer face of the web further enhances the joint efficiency by arresting the cracks radiating inward from the corner (Nilsson and Losberg 1976).
(a) (b)
Figures (a) and (b): Comparative efficiencies of T-joints subjected bending moment: (a) 24 to 40% and (b) 82 to 110% depending on reinforcement ratio. (Darwin et al. 2016 [1] after Nilsson andLosberg1976 [2])
(c) (d)
Figures (c) and (d): T-joint behavior subjected to moment: (a) bending moment and resulting shear forces; (b) strut-and-tie model. (Darwin et al. 2016 [1])
[1] Nilsson, I. H. E., and <g class="gr_ gr_51 gr-alert gr_spell gr_inline_cards gr_run_anim ContextualSpelling ins-del multiReplace" id="51" data-gr-id="51">Losberg</g>, A., 1976, "Reinforced Concrete Corners and Joints Subjected to Bending Moment," ASCE Structural Division, Vol. 102, No. ST6, pp. 1229-1254.
[2] Darwin, D., Dolan, C. W., and Nilson, A. H., 2015, Design of Concrete Structures, 15th ed., McGraw-Hill, New York, pp. 776.
Krishna Ghimire EIT, A.M.ASCE
Lawrence KS
