There are things that are not certifiable, so I exclude them in my certification. Unless you were present and watched every item being constructed and have product quality certifications, you can't certify it. You can't certify to the quality of construction. You can only certify as to what you can see. Below is a certification I use and modify for each project:
I. Certification:
The infrastructure installed in
PROJECT consisted of potable water lines (including fire hydrants), sewer lines (including pump station and forcemain), electrical boxes and lines, storm sewers, storm inlets, stormwater detention ponds, curbing and asphalt pavement section.
COMPANY prepared a Record Drawing based on our field survey of some of these items. Neither material used or quality of construction were verified. This certification is to the storm drainage structures and pipes, including sizes (where shown), horizontal and vertical locations, stormwater detention ponds, curbing and asphalt pavement surface at the time of the survey.
This certification is based only on visual observation at the surface. A storm drainage tabulation is provided on the Record Drawing by
COMPANY sealed by
SURVEYOR, RLS, dated
DATE, showing the design and constructed sizes, with length, slope and elevations comparisons. The public roadway is currently ready to receive the asphalt surface layer.
I hereby certify that I am a licensed professional engineer in the State of
STATE, and to the best of my knowledge, information and belief, the infrastructure was constructed in general conformance with the plans and specifications, and according to the information provided on the Record Drawings.
Some cities have their standard certifications, but we cannot sign those without some disclaimers. I usually totally rewrite them.
Mark Lee M.ASCE
New Business & Engineering Development
Site Engineering Consultants
Murfreesboro TN
(615) 890-7901
