Michael,
If the IBC is the building code adopted by the authority having jurisdiction, it is the legal document governing design in that jurisdiction. ASCE 7 is a referenced standard adopted by the IBC. Therefore if you are using the IBC, the loading criteria from ASCE 7 would apply, unless there are local amendments with other requirements. When there is a discrepancy between the IBC (the code) and ASCE 7 (the referenced standard), the Code prevails. However it is typically acceptable to work with both the owner and the building official if you want to exceed the code or use a more stringent design criteria, including anything in ASCE 7 that is beyond the code requirements.
DISCLAIMER: Reliance on the contents of this communication is solely and completely at your own risk; therefore, we advise you to exercise a reasonable degree of caution in your use of any information or advice contained herein. This information is provided for general informational purposes only and is not intended in any fashion to be a substitute for professional consultation. Under no circumstances does ASCE, its affiliates, officers, directors, employees, or volunteers warrant the completeness, accuracy, or relevancy of any information or advice provided herein, or its usefulness for any particular purpose. ASCE, its affiliates, officers, directors, employees, and volunteers expressly disclaim any and all responsibility for any liability, loss, or damage that you may cause or incur in reliance on any information or advice provided herein.
Jennifer Goupil P.E., F.SEI, M.ASCE
Fort Collins CO
