Good idea! Low cost level of service improvement. Looks like a candidate for useful universal information to include in the ASSHTO GDHS after your research is able to produce an application level design guide. Yes, as Fraser Howe states there are many things to consider. Not the least of which are approach speed, exit taper, turning path , entrance taper, flow gap, stacking capacity, sight distances, grades, weather conditions, and other design features normally used for intersections. Signage and enforcement would be included, as well as driver population characteristics (aggressive, moderate, casual). Most likely prohibit trucks, buses and pedestrians. Maybe bicycles as well.
As with the normal GDHS presentations, please convert your simulations and research to practical NCN style (no computer necessary) designer-friendly tables, diagrams, and verbiage. NCN style is best and quickest way for an experienced geometric designer to sketch before CADemizing it.
I think an important factor missed by many designers is the 2-second rule of roadway conditions changes. That is, try to provide a minimum of 2 seconds and as much as 6 seconds minimum driving time between roadway condition changes (such as lane width, lane drops, shoulder width, or other geometry) in order for the driver to adjust to the new condition. Example distances are shown in the GDHS Decision Sight Distance tables. This rule should determine the minimum distance needed between the u-turn and the roundabout.
Hope you get some good help on your project.
Norman Voigt P.E., L.S., F.ASCE
Pittsburgh PA
Sent: 08-15-2019 12:27
Subject: Analysis of rounabout by simulation model (PTV Vissim).
First of all, you are exactly right owing to originally we had two lanes which was the reason for queues and delays. What we have done is provided three lanes instead of two under existing geometry in PTV Vissim and got no delays and queues.
Secondly, the vehicles take a smooth U-turn without any queues due to now we have three lanes. lastly, the U-turns are provided in the locality where there have streets and junctions because this place is located in Central Business District (CBD). Thanks.
Muhammad Khan Aff.M.ASCE
University Of Peshawar
Peshawar
Sent: 08-13-2019 16:39
Muhammad, The actual site conditions will determine if the propose u-turns will operate effectively on each approach:
- Are the roadways wide enough to allow vehicles to complete a U-turn? On US roads you need 3 receiving lanes for most vehicles to complete the turn.
- Can you provide a left-turn queue to accomodate the peak-hour U-turn volume, without backing-up into the left-most through lane?
- If the U-turn is located at, or near, a cross-street intersection, will the u-turns interfere with the cross-street operation?
These are just a few of the considerations that will determine if a modeled scenario will not only improve the roundabout operation, but also not degrade the operation on the approach roadways.
Fraser Howe P.E., F.ASCE
Sent: 08-13-2019 12:35
The U-turns are provided within the range of half a Kilometer. If you need my thesis and I can provide it. My thesis has all graphs and PTV Vissim analysis data table. Thanks
Peshawar
Sent: 08-13-2019 09:09
Muhammad,
Can you provide a graphic of the roundabout showing where the u-turns were placed on the approach roadways?
