Expand all | Collapse all
More Abnormal, Less Normal: The Mississippi River's Last Decade
  • 1.  More Abnormal, Less Normal: The Mississippi River's Last Decade
    Posted 26 days ago
      |   view attached
    The Mississippi River appears to be swinging harder between extremes - flood and drought. What do you see as the implications for the future of the waterway and the infrastructure that depends on it? Are you seeing the same pattern on other U.S. waterways?
    Some context from the Lower Mississippi. The Bonnet Carré Spillway, long expected to open about once a decade, opened five times from 2016 to 2020, including the only double opening in its history in 2019. Then the river flipped: four straight years of drought (2022–2025) required an emergency underwater sill every year to keep saltwater away from New Orleans' drinking water.
    Next spring marks 100 years since the 1927 flood, which gave us the system that carried us through all of this. That makes this a good moment for both a celebration and an evaluation: is a system built on the last century's record ready for the next one?
    Dennis Lambert, M.Eng, P.E., Fellow of ASCE
    Sole Proprietorship
    3039 LA971
    Lettsworth, LA 70753
    Cell: (504) 451-2990
    Email: dennis.g.lambert@...
  • 2.  RE: More Abnormal, Less Normal: The Mississippi River's Last Decade
    Posted 20 days ago
    Dennis – your post and the Figure you attached – indicate something very important and alarming – not only for the Mississippi River system – also for other major alluvial rivers. And anthropocentric interventions of various sorts and the ongoing global imposition: Warming Climate just add more layers to the exacerbation on top of regular Environmental Controls.
    As we all know, also discussed in one Collaborate thread – one implication of warming imposition is that treating long-term data as something stationary is no longer a valid reality. The presence of positive or negative long-term trend in many forms of hydrologic data makes non-stationarity apparent.
    On other major rivers – here is something I can share based on my relatively short experience in another major river system in the world – the Ganges-Brahmaputra-Meghna (GBM). In 1964, Prof. T Thijsse of TU Delft (founding pioneer of water engineering in the Netherlands) – on a fact-finding mission to then East Pakistan – identified GBM hydraulics as a high-low seasonal: the 'high flow' and 'low flow' problems. This and other papers are complied in a volume: Morphological processes in the Bangladesh river system.
    How best to address the high-low problems to differentiate one system from another? I have tried to answer this question by defining a Seasonality Index (mean monthly/mean annual), SI. It is interesting that SI represents a signature characteristics of rivers – showing the spacetime connotation of a system, its identity – which are all very relevant for river management issues.
    The monsoon-influenced GBM system – shows seven river stage-SI from the flat-low during January-February to variable peaks in July-August. All these are in: The Characteristics and Mobility of Some Major Rivers in Bangladesh. The Brahmaputra River of the GBM system has a flow-SI that varies from 0.2 in February to 2.4 in July.
    On intrusion of salt water – into deltaic estuaries during the low-flow period – I have begun to look into this problem from the viewpoints of Force Field terms, as in the Force Fields in a Coastal System. The low-flow strength of Land Drainage Force Field (LDFF) invites salt-water intrusion – that changes to pushing fresh water out into the sea during high-flow LDFF.
    As you're aware on the history of major engineering interventions, and of Mississippi River System issues – that have attracted some lively discussions in the Collaborate Forum. Here are some links: Over Engineered Mississippi River?; New Orleans' Levees Sinking after Massive Upgrading; Tropical Storm Barry and New Orleans
    And we know about the extensive amounts of literature on the river, some titles are: the 2012 USGS C-1375; the1998 USACE Mississippi River Flood Control; the Boyce Upholt's literary outlay: The Great River: The making and Unmaking of the Mississippi; and 1997 JM Barry book, Rising Tide: The Great Mississippi Flood of 1927 and How it Changed America.
    Dr. Dilip K Barua, PhD
    Website Links and Profile
  • 3.  RE: More Abnormal, Less Normal: The Mississippi River's Last Decade
    Posted 16 days ago
    Dilip, thank you for this, and for bringing the GBM into the conversation. The comparison is useful because the Mississippi and the Ganges-Brahmaputra-Meghna share the same core problem you describe. The river has to be managed for both its high-flow and its low-flow regimes, and the two keep moving further apart.
    Your point on non-stationarity is exactly where the Frederick (2019) and Wolverton (2025) studies lead. Once the trends are accelerating, a design or operating rule based on a stationary record keeps aging, even if the record behind it is long. Bonnet Carré was expected to open about once a decade, and the last ten years broke that assumption on both the flood side and the drought side.
    Your Seasonality Index raises a question I'd like to put to the group. If we computed a flow SI for the Mississippi at Tarbert Landing by decade, would the signature itself be shifting? Higher spring peaks and deeper late-summer lows would show up as a wider SI range, which would be a simple, transferable way to measure "more abnormal, less normal."
    Your Land Drainage Force Field framing also fits our saltwater problem well. When the river's low-flow push weakens, the wedge moves up the channel toward Belle Chasse, and that's when the Corps builds the sill. Seeing it as a balance of forces, rather than a single threshold, may help us anticipate those years earlier.
    Thanks also for the reading list. Rising Tide and Upholt's The Great River are good company as we approach the 1927 centennial next spring.
    Dennis
    Sole Proprietorship
    3039 LA971
  • 4.  RE: More Abnormal, Less Normal: The Mississippi River's Last Decade
    Posted 9 days ago
    Dennis – thanks for your kind words, and for initiating the thread that has energized many, including me. It invoked discussion of many scientific details and brought them up in the arena of critical examination. These are helpful in many different ways – in planning, managing and designing Civil Engineering on Our Seashore.
    Your latest post together with the attached synthesis report – have many scientific info on the Mississippi River (MR) hydro-morphologic-navigational transformation (if we can call it this way) – the river is going through – for that matter many other systems debouching out into coastal oceans (e.g .An Alluvial River's Sedimentary Functions). The hydroclimate is an open vista of the processes and factors – of the Environmental Controls and anthropogenic interventions if one looks through the lens of force-field dynamic equilibrium.
    Here are something more I like to add to further the conversation:
    Non-stationarity. The phenomenon of stationarity, weak-stationarity or non-stationarity – usually manifests itself in the statistical time-series data analyses – in the first moment (mean, moving-average trend) and in the second moment (variance or energy). The second moment is very important – because it is a quantitative measure of – whether or not a certain non-stationarity is relevant or important.
    Seasonality Index, SI. This index is easy to compute with any descriptive statistics routine. Apart from transferability or comparing one-system with another – if SI time-series of multiple years are superimposed they would indicate at least three things: (1) what have been or are happening in the basin, either Natural or anthropogenic – e.g. damming would show a sudden drop or kink in SI-flow; (2) a rising or falling SI and its magnitude would be a qualitative indicator of the strength (variance, not mean) of non-stationarity (would indeed be an indicator of "more abnormal, less normal."); and (3) as discussed, the potential of salt-water intrusion when low-flow SI falls below a certain threshold.
    Land Drainage Force Field (LDFF): Indeed, Seeing it as a balance of forces, rather than a single threshold – that is what force-field characterization implies. It comes from dynamic equilibrium of processes and factors – but then labeling or naming for convenience in terms of the dominant one. It is to differentiate one certain regime from another – such that resources and investigations can focus on the dominant factors. For example, a MOFF (Metocean Force Field) regime is fundamentally different from the LDFF – they need different outlook of solving or investigation (not that MOFF factors are not active in the LDFF areas, only that they are less dominant).
    They come from Common Sense Hydraulics and from the rationale of the relative magnitude of hydraulic processes – presented in the 2017 Encyclopedia of Coastal Science Chapter Seabed Roughness of Coastal Waters.
    Flocculation. If I am correct, you mentioned somewhere about the increased observation of flocculation during the 'low-flow' drought period at some locations. Without having firsthand familiarity with the intricate nature of MR hydraulics – I would expect so. In 2008 – I wrote a discussion on the 2007 Bill McAnally et al Journal of hydraulic Engineering paper: Discussion of "Management of Fluid Mud in Estuaries, Bays, and Lakes. I: Present State of Understanding on Character and Behavior". Presented there – how the salinity-induced flocculation behaves in the case of Sandwip Channel Mud (Mostly Estuarine Mud channel shown in the image pasted in: Coastal Ocean Currents off Rivermouths). Some important factors for such flocculation or aggregation of fine particles – are the composition of clay-size mineralogy, salinity.
    But there are more to it. One important being the tidal amplification (let us say during low-flow drought period) and asymmetry of the tidal wave (e.g. Barua, 1991, Tidal observations and spectral analyses of water level data in the mouth of the Ganges-Brahmaputra-Meghna river system, Mombasa, Kenya, pp. 1202-1215, COPEDEC-PIANC). The processes usually result in upstream residual transport and accumulation of fines, forming a fluid-mud layer and sedimentation through consolidation (e.g. two of my Dissertation Chapters published by Elsevier: 1990 Chap 2; 1994 Chap 4); and in Barua,1994 On the hydraulic behavior of Karnafuli River estuary, Bangladesh. Japan Society of Civil Engineers and Coastal Engineering Research Council and the American Society of Civil Engineers (ASCE). Abstract No. 35, pp.116-117). The investigations in the Karnafuli River mouth show a clear dependence of Surface Suspended Sediment Concentration on tidal range.
    Again, great to be in the scientific conversation of a great river.
  • 5.  RE: More Abnormal, Less Normal: The Mississippi River's Last Decade
    Posted 2 days ago
    This paper is really aligned with our comparison of the Frederick and Wolverton reports - More Frequent, Faster, and Seasonally Reorganized Drought-to-Pluvial Transitions in U.S. Cities More Frequent, Faster, and Seasonally Reorganized Drought‐to‐Pluvial Transitions in U.S. Cities - Copana - 2026 - Earth's Future - Wiley Online Library
    Sole Proprietorship
    3039 LA971
  • 6.  RE: More Abnormal, Less Normal: The Mississippi River's Last Decade
    Posted 16 days ago
    Your observations are consistent with mine, Dennis. In the mid-1980s my group noticed growing non-stationarity in river flow statistics in several locations nationwide, which we came to recognize as a result of climate change, confirmed for some regions by the IPCC. More and longer Mississippi River floods and droughts that we are experiencing can be seen as part of those trends.
    Compounding complications include the documented substantial reduction on Mississippi River sediment load and the unknown but lengthy (greater than 50 years*) morphologic equilibrium time of the river.
    Bill Mc
    *Thomas, William A., Michael J. Trawle, Ronald E. Heath, Carol P. Richards, and Cherie P. Price. 2018. HEC-6T One-Dimensional Model Study. Louisiana Coastal Area Program, Mississippi River Hydrodynamic and Delta Management Study, Prepared for Coastal Protection and Restoration Authority, Office of Coastal Protection and Restoration, State of Louisiana, by USACE, ERDC, Vicksburg MS.
    ENGINEER
    Columbus MS
  • 7.  RE: More Abnormal, Less Normal: The Mississippi River's Last Decade
    Posted 11 days ago
      |   view attached
    Bill, thank you. Coming from someone whose group was watching flow statistics go non-stationary in the mid-1980s, decades before the published trend analyses caught up, that is confirmation of the most valuable kind: professional observation running ahead of the literature.
    Non-stationarity is, to me, the engineering crux of this whole thread. Every operating assumption on this river, from the frequency curves behind the levee grades to the once-a-decade expectation for Bonnet Carré, was built on the premise that the statistics of the record are stable. Your observation and Wolverton's accelerating trend rates say the same thing from two directions: the statistics are moving. That is exactly why I keep arguing the last 10 years and the last 100 belong in the same conversation, and it sharpens the centennial question this thread will turn to next spring: an evaluation of a system designed against one century's record as it enters a century whose record will not sit still.
    Your second point may be the most underappreciated factor in the whole discussion. If the river's morphologic equilibrium time exceeds 50 years, then today's channel is still adjusting to decisions made generations ago, the cutoff program, the reservoirs trapping the sediment supply, each deepening, while the forcing on top of it keeps changing. The river never catches up. That reads directly onto what we are seeing at the bottom end of the system: the growth of Neptune Pass, the shoaling behavior in Southwest Pass, and the 2026 reports of flocculation above the Head of Passes all look like transient responses of a system chasing a moving target. It also dovetails with the point Nancy raised above: the recent sills were required at flows that formerly needed none, which is what you would expect when channel geometry, outlets, and sediment supply are all still in motion beneath the hydrology.
    The Thomas et al. (2018) HEC-6T reference is a welcome addition and goes on the synthesis reading list alongside the Tulane salinity work Nancy cited. Sediment is the half of this story the hydroclimate synthesis touches only lightly, and your perspective on it would be invaluable when the centennial evaluation gets underway. I hope you will stay in the thread for it. Take a look at the attached which was reviewed by Joey Winham and his team in MVD's Watershed Division.
    Sole Proprietorship
    3039 LA971
  • 8.  RE: More Abnormal, Less Normal: The Mississippi River's Last Decade
    Posted 16 days ago
    Edited by Jill Sanders 9 days ago
    A few more details for anyone who wants the numbers behind the question.
    The Bonnet Carré Spillway opened ten times in its first 74 years, close to the once-a-decade pace it was planned around. It then opened five times in five years (2016–2020). In 2019 the river stayed above flood stage at Baton Rouge for 211 consecutive days and mean annual discharge at Vicksburg reached 1,211,000 cfs, the highest on record. The low-water side broke records too. During the 2022–2025 droughts the 2023 salt wedge reached River Mile 69.4, and for the first time anywhere a navigation notch was cut into the sill so deep-draft ships could pass over it. In 2025 the river came close to needing a spillway opening and a sill in the same calendar year, and in 2026 pilots reported flocculation above the Head of Passes for the first time.
    Here is the careful part, because "unprecedented" is a word this river has taught me to respect. Working with Sean Duffy of the Big River Coalition, I recently completed a synthesis of two USACE Mississippi Valley Division precipitation studies, Bill Frederick's (2019) and Anna Wolverton's (2025). The basin has always cycled between wet and dry. Saltwater came farther upriver in the 1950s than it has recently, and the Baton Rouge record low dates to 1894. What has changed is the amplitude and the pace. Precipitation trends are accelerating (the Ohio Basin's rate has nearly doubled since 1994), major-flood frequency at Cairo has doubled, and the same warming that loads the atmosphere for bigger floods dries the soils faster between them. The basin now spends less time at "normal" and more time at both extremes: more abnormal, less normal.
    That is why I think the last 10 years and the last 100 years belong in the same conversation. A time-series look at the full record, not just the recent decade, is what should shape the operating and design assumptions for the next 100 years.
    Sole Proprietorship
    3039 LA971
  • 9.  RE: More Abnormal, Less Normal: The Mississippi River's Last Decade
    Posted 11 days ago
    Yes, there's a lot to be learned from the historical record.  The period since 2015 is one set of data about river flow and SLR that needs to be considered, the period from 1990 - 2015 is another, and 1950-1990. Low flow today should be investigated for comparison with older "drought years" cited above, but as particular cases, evaluating upstream and tributory form as well. The conditions in New Orleans and below are part of an even more complex and dynamic system than the monitoring data from parameters that were used during the 2019 levee redesign project. The global water cycle disruption, especially since 1990, and the river/tributary channels matter, too.  Are there historic high flows before 1990 that rival those seen today (daily/weekly, rather than average).
    Sarah Simon P.E., M.ASCE (retired)
    Sustainability Committee
    BSCES
    Ipswich MA
  • 10.  RE: More Abnormal, Less Normal: The Mississippi River's Last Decade
    Posted 9 days ago
      |   view attached
    Sarah, thank you. Your three periods are a good way to frame it, and you're right to ask about daily peaks rather than averages. The answer is yes. Peak flows before 1990 rival, and in places exceed, anything in the recent decade.
    At Vicksburg, USGS lists measured peaks of 2,080,000 cfs in 1937 and 1,960,000 cfs in 1973. The 1927 peak is estimated at about 2,280,000 cfs. The 2019 peak was 1,890,000 cfs, lower than all three. The only recent flood to top them was 2011, at 2,310,000 cfs. Upstream at Arkansas City, the estimated 1927 peak of 2,470,000 cfs is still the largest on record. Even that understates 1927, because levee crevasses upstream drained enormous volumes before the water reached the lower gauges.
    So 2019 did not stand out for its peak. It stood out for its duration: 211 consecutive days above flood stage at Baton Rouge, against the 1927 record of 135 days.
    The low-water side supports your suggestion to treat the drought years as individual cases. At Memphis, 1988 set a record low of minus 10.7 ft. Then 2022 broke it at minus 10.8 ft, and 2023 broke it again at about minus 12.0 ft. At Vicksburg and Baton Rouge, the 1988 lows (minus 1.6 ft and 1.8 ft) are still lower than anything in 2022 to 2025. The saltwater sill, first built in 1988, was needed again in 1999 and 2012, then every year from 2022 through 2025. That clustering, not any single low stage, is what's new.
    Your point about the design basis matters too. The MR&T system is built around the Project Design Flood, a hypothetical flood developed in 1954 to 1955 and adopted in 1956. It carries 3,030,000 cfs at the latitude of Red River Landing, well above any observed peak. That margin is a real strength. The open question for the centennial is whether a design basis built on 1950s assumptions still accounts for the duration and the rapid swings we're now seeing, not just the peak. I have attached the Hydroclimate Memo that we wrote - with the Big River Coalition and reviewed by the MVD Watershed Division. Dennis
    Sole Proprietorship
    3039 LA971
  • 11.  RE: More Abnormal, Less Normal: The Mississippi River's Last Decade
    Posted 16 days ago
    Thanks, Dennis, for posting.  It is good to have discussions related to the Mississippi River.
    I do disagree with your conclusion that there have been four consecutive years of drought, 2022-2025.  Here are my thoughts.
    I find that the saltwater sill presence does not provide the best representation of the history of drought conditions on the Mississippi River.  First, the sill was authorized in the mid-1980s as part of a comprehensive mitigation for deepening the navigation channel; the chart in your discussion does not show drought years prior to the sill authorization.  Low water conditions in the New Orleans area have occurred in 1936, 1939, 1940, 1952, 1953, 1956, and other years, including 1930 and 1980-81.  Second, besides river flow, other factors can affect saltwater wedge propagation and the need for the sill, including the growth and development of Mississippi River outlets, navigation channel deepening, and sea level rise.  One river outlet, Neptune Pass, rapidly developed since its inception between 2019 and 2021, diverting increasing amounts of Mississippi River flow.  The navigation channel also was deepened from 48.5 ft below MLLW to 50 ft below MLLW in the 2020-2022 timeframe.
    Engineers and scientists at the Department of River-Coastal Science and Engineering, Tulane University have published a paper that documents Mississippi River salinity intrusion modeling performed by Tulane.  The paper indicates that "while sea level rise and deepening of the navigation channel contribute to upstream wedge movement, excessive water loss through a series of lateral crevasses was a primary cause of the upriver wedge propagation distance" for the years 2022-2024.
    Flow data for the Mississippi River below Old River (see Rivergages.com) can demonstrate the influence of loss of main channel flow on the construction of the sill.  Flow data shows higher flow averages during the low flow period for the years 2024 and 2025 when compared to other years where drought conditions are present or a sill constructed.  If you consider the lowest 30-day average flow for each year, the years 2000, 2005, and 2006 all have smaller flow averages than the years 2024 and 2025, yet no sill was constructed.
    minimum 30 day average for July-December
    The flow data also shows the magnitude of drought conditions during the 1930s, with 6 years having the lowest 30-day average flows less than 150,000 cfs, and drought conditions during the 1950s, where there were four consecutive years with lowest 30-day average flows less than 150,000 cfs.
    With the reservoir expansion in the Mississippi Basin that occurred between 1950 and 1980, low flow conditions on the river have changed with reservoirs providing significant changes to low-flow parameters.
    Munoz et al have documented an increase in low flow during the period of reservoir expansion.  Their study showed that low flow is projected to become less severe in terms of discharge and duration through to the end of the 21st century.    There may be other studies that confirm or refute their findings.
    A useful tool to evaluate drought conditions may be found at the National Integrated Drought Information System web page
    https://www.drought.gov/watersheds/mississippi-river-dashboard#drought-conditions
    on the drought.gov portal.   The drought index and the standardized precipitation index (SPI) for the entire Mississippi River basin or its sub-basins can be displayed.  Here is one of the plots that can be created, showing SPI values for the entire basin for the period 1987-2026.
    SPI for 1987-2026
    The SPI plot captures the drought conditions found in 1988, 1999, and 2012, as well as the wet conditions during 2018 and 2019.  The 2011 flood event would be better represented by information for sub-basins, as the lower Mississippi River sub-basin, including the Red River basin, was in low flow/drought conditions during the flood event, affecting the basinwide SPI.
    references
    Kazmann, Rafael G. and Johnson, David B., 1980, If Old River Control Structure Fails (The Physical and Economic Consequences), Louisiana Water Resources Research Institute, Bulletin 12, September 1980, page 21.
    Khalifa, Ahmed, et al, 2026, Exploring salt wedge dynamics and nature-inspired mitigation measures in the lower Mississippi River, Estuarine Coastal and Shelf Science, Volume 334, 1 July 2026.
    Muñoz, Samuel E. et al 2023 Mississippi River low-flows: context, causes, and future projections, Environ. Res.: Climate 2 031001, 2026.
    Remo, Jonathan W. F., et al, 2018, Assessing the impacts of dams and levees on the hydrologic record of the Middle and Lower Mississippi River, USA, Geomorphology, Volume 313, pages 88-100, 15 July 2018.
    Nancy Powell P.E., BC.NE, BC.WRE, M.ASCE
    Hilton Head Island SC
  • 12.  RE: More Abnormal, Less Normal: The Mississippi River's Last Decade
    Posted 11 days ago
      |   view attached
    Nancy, thank you. This is exactly the quality of discussion I hoped the thread would draw, and you have improved the record on several points.
    You are right about the central one, and I will state it plainly: "four straight years of drought" was imprecise. The defensible statement is four consecutive years of emergency sill construction, which is an operational-response record, not a drought index. Since the sill was authorized in the mid-1980s as mitigation for the channel deepening, no comparable response record can exist for the 1930s, 1950s, or 1980-81 low-water years you list, several of which were more severe by lowest 30-day flow than anything since 2022. The full synthesis behind this post is careful on exactly that point (saltwater advanced farther upriver in the 1950s than in any recent event, and the Baton Rouge record low dates to 1894), but the post compressed that nuance away. In a post arguing that "unprecedented" has been worn smooth, I owe the same discipline to "drought." Consider it corrected.
    Your flow comparison may be the most important point in your reply, and it strengthens the argument I actually care about. If the lowest 30-day flows of 2024 and 2025 ran higher than in 2000, 2005, and 2006, years that required no sill, then the recent sills were needed at flows the river formerly shrugged off. That is the signature of non-flow drivers moving the response threshold: the growth of the outlets (Neptune Pass above all), the 48.5-to-50-ft deepening, and sea level rise. The synthesis lands where the Tulane work you cite lands. It documents USACE's estimate that the crevasses below Venice now draw 30 to 51 percent of the river's stream power, the first reports of flocculation above the Head of Passes in 2026, and the Coalition's modeling partnership with Tulane's Department of River-Coastal Science and Engineering. Khalifa et al. (2026) finding excessive crevasse water loss to be the primary cause of the 2022-2024 wedge propagation is welcome confirmation, and I will add it to the synthesis reference set.
    On Muñoz et al., agreed, and consistent with the synthesis, which states that the reservoir benefit remains fully intact and cautions against reading managed mainstem gauges as climate signals. I think both findings hold at once: reservoir operations have raised discharge-based low flows and are projected to keep supporting them, while the meteorological record (Wolverton 2025: faster wet-dry transitions, rising evapotranspiration, flash-drought behavior against a wetter annual baseline) shows the forcing growing more volatile. How those two trends net out on the river is the most interesting open question for the next update of this research, and the NIDIS SPI tools you point to are the right instrument to bring to it.
    Thank you also for the Kazmann and Remo references. If you are willing, I would value your eyes on the full synthesis, and I hope you will weigh in when this thread turns to the 1927 centennial. A record as long as this river's deserves reviewers who know where it is buried. We did have Joey Windham, Chief, Watershed Division for MVD; Justin Giles, on staff at the Watershed Division for MVD; also, Don Duncan and Drew Smith reviewed our Hydroclimate Memo - see attached.
    Sole Proprietorship
    3039 LA971
  • 13.  RE: More Abnormal, Less Normal: The Mississippi River's Last Decade
    Posted 11 days ago
      |   view attached
    Picking up on the centennial. Next spring marks the 100th anniversary of the 1927 flood, the disaster John Barry chronicled in Rising Tide. It killed hundreds, displaced nearly a million people, and gave us the 1928 Flood Control Act and the Mississippi River & Tributaries project. Every operation in this thread (Bonnet Carré, Morganza, the levees that held in 2019) exists because of what the nation decided after 1927. The recent record is, in a real sense, the centennial report card on that decision.
    This one is personal for me. My great-grandfather's home at Innis, in Pointe Coupee Parish, went under in 1927. Eighteen months later he helped organize the Pointe Coupee Flood Protection Association to argue the parish's case under the Jadwin Plan. His letters were typed on an Underwood Noiseless that still sits in my office, in the farmhouse he bought in 1917, where I live today behind the Morganza Floodway. His grandfather ran the steam dredge that dug the drainage canals behind New Orleans. The Corps and the Mississippi River Commission are already capturing stories like these through centennial commemoration interviews this fall, and ASCE should be part of this moment too.
    So here is the crowdsourcing question: what should ASCE do to mark the 1927 centennial, as both a celebration and an evaluation? A commemorative webinar series pairing the history with today's operators? Oral histories from members whose families lived it? A Rising Tide reading series? Technical sessions on what the MR&T got right and what a second century demands? Reply with what you would want to see discussed or memorialized. The best commemorations get built the way the levees did, by everyone who has a stake in the outcome. I have attached a memo I wrote with the Big River Coalition and reviewed by the MVD's Watershed Division. There definitely should be a conference dedicated to what is happening on the river.
    Sole Proprietorship
    3039 LA971
