Thank you, Ronald! In addition to low rise residential construction, would pre-engineered metal buildings with single skin panel and cold-form girts and purlins as their cladding also fall into this light frame construction?
Daniel Rhoades P.E., M.ASCE
Oklahoma City OK
Sent: 04-30-2026 09:52 AM
Subject: ASCE 7-22 section 12.2.5.6.1b (ordinary moment frames within light frame construction)
That section of ASCE 7 is intended to permit the use of ordinary steel moment frames in typical low-rise residential construction, commonly composed of repetitively framed wood stud or cold formed steel stud walls. It is not uncommon in such construction to use moment frames as the lateral support along walls with large window and door openings, and at the fronts of garages. OMF is permitted because the reality is that it is very difficult to provide the lateral torsional bracing required for IMF and SMF beams, per AISC 341, with the light frame diaphragms. Thus, OMF's were permitted, as a matter of practicality and with the understanding that loading on such frames would likely not reach yield levels, as the frame design is controlled by deflection and the damping in such structures is higher than the assumed 5%. So think - single family home, 3-story apartment buidling/townhouse or similar construction. Note that in the time since this provision was introduced, Simpson Strong-Tie brought their Stong Frame to market providing a practical SMF alternative for this construction type.
