Per section 11.7 of ASCE 7-16, "Buildings and Other structures assigned Seismic Category A need only comply with section 1.4", except tanks in Risk category IV which shall satisfy the freeboard requirement in section 15.6.5.1. All Nonstructural components in seismic design category A are exempt from seismic design requirements.
Section 1.4 shows lateral forces to be calculated from the equation 1.4-1 and states "in each direction the static lateral forces at all levels shall be applied simultaneously"
So from my interpretation for buildings and other structures you would simply use Fx=0.01Wx for Seismic Category A, all other buildings and structures of Seismic Design Category B,C,D,E,F would need to follow other guidelines to calculate base shear as outlined in the code.
Michelle Hudson EIT, A.M.ASCE
Design Engineer
Altoona IA
