ASCE 7 -16 Chapter 13 discusses requirements for support of non-structural components such as cable trays.
ASCE 7-16, Chapter 13, Item 3.3.1.1 gives some equations for horizontal forces for seismic design for components that include an importance factor. The importance factor is given by that stated in Section 13.1.3 and is either 1.0 or 1.5.
For a facility currently in the design phase, I would use 1.0 for the importance factor for non-structural components.
Ii is possible that if these loads were secured to a larger structure, that there would be no question about the importance factor.
If an independent structure will be used to support these non-structural components (cable Trays), does the independent structure (which could be a T-post) use the same coefficients as given in Section 13.1.3?
should the seismic design loads be adjusted by the importance factors given in Table 1.5-2 based on Risk Category. For Risk Category III, the importance factor would be 1.25.
Which importance factor should be used?
Please provide some insight?
David Brosig P.E., M.ASCE
Engineer
Abilene TX
