Hi,
Make sure that everyone knows what the conditions are based on the results of your calculations.
In 5 years there is the possibility of many things happening. For example, if they need to do work on the roof then the live load might exceed capacity if they don't stop work on the utilities being supported from below.
Make sure to check ice and ponding loads as well. Are you sure that with this roof there are no wind loads in the direction of the gravity loads? For a project I worked on we had wind tunnel results and there were negative and positive pressures on the roof.
Make sure the owner has a plan to ensure that the conditions are not forgotten if there is a change in personnel during those 5 years.
Sarah Halsey P.E., M.ASCE
New York NY
