If you are truly concerned about the building's performance, then use ASCE 41 and upgrade the entire building to conform to appropriate performance objectives. Otherwise, just use ASCE 7 and conform to its requirements.
Sent: 07-24-2023 03:09 AM
Subject: An addition to existing RCC structure which was designed for seismic-resistance force as building frame system (Ordinary shear wall) & the addition as per the code require the addition to be special moment frame system
Ronald, thanks for your feedback.
For your point no.1: The use or selection of R is relevant to the seismic design category which is classified as "D" for the addition & this requires to comply with Table 12.2-1 ASCE for the selection of seismic force-resisting system which also will end up with using special seismic force-resisting system accordingly higher R & here is our concern regarding the performance of the overall building seismic force-resisting system with different ductility behavior between the old existing part & the new addition.
For Point no.2: I am trying to avoid upgrading the entire existing structure due to a small addition
Almontasir Salah
Se.Structural Engineer
EHAF Consulting Engineers
UAE-Abu Dhabi
Sent: 07-20-2023 01:39 PM
Almontasir - You are correct that under ASCE 7-16, upgrade of the entire structure would not be required, assuming that the new addition conforms to the applicable requirements of ASCE 7 for new construction and that the demand on existing elements of the structure does not increase by more than 10%, unless the elements have the capacity to resist the increased forces. Note that in the U.S., local building codes often adopt requirements for additions to existing buildings that are different from those in ASCE 7, in which case the local building code requirements would apply. Because of this, in the 2022 edition of ASCE-7, Appendix 11B was deleted.
My primary concern with placing a new special moment frame on top of the existing shear wall is that the design forces for the special moment frame would be substantially less than the stucture is capable of transmitting to the new strucutre, which could result in performance issues. You could "manage this" in several ways:
1- Use an R factcor for the new addition that matches the equivalent R factor used in the design of the original structure (but not less than that specified by ASCE 7-16, presently. This would give sufficient strength to the addition to delay onset of premature damage, relative to the balance of the structure.
2- Rather than using ASCE 7 for design, use a performance-based approach, such as ASCE 41 to assure that the addition will perform as anticiapted under the building code. Note that you may find the existing building is inadequate under ASCE 41. In that case, it would be responsible to upgrade the existing structure.
