Thank you, Darya, for raising this thoughtful prompt. I've found that integrating VOWD logic into early-phase planning benefits greatly from a constraint-aware lens, especially where physical access and financial bandwidth are tightly interlinked.
I've been working on a planning layer that sits between the Project Development Plan and the first formal update essentially a constraint-based prioritization statement. It ranks activities not just by sequence but by feasibility under physical and financial limitations. This helps surface risk early, before baselines are locked.
Grateful for your insights, and looking forward to learning more from your approach
Note
When I reach safer place with electricity availability,
I'll send to you my modified SW - Template of Statement of Work with a spread sheet that you can track each formula as you like.
Best regarding
Abubakr Gameil
[Abubakr] [Gameil] [R. ENG, M. ASCE®️, SEI Member]
[Chairman & Director General]
[Almanassa Engineering International Co. Ltd]
[Khartoum] [Sudan]
