[Pardon me in advance. Up late working]
George, after reading this my initial thoughts went to the topographic factors in calculating wind loads where there is a speed-up at the top of a hill. I had used topography factors to calculate an increase in wind speed for a splash wall at the top of a "hill". I may be the only one challenged to comment on an element of a report without a few more details (i.e., elevated house on piles, low pitch roof, etc.) and characterization of terrain, topography, etc.
When it comes to various analysis methods, I believe we are often challenged by the idea of "exactness" when attempting to find "the answer". I imagine that the gap between the theoretical answer is aided by the use of a factor of safety and reality falls within or under the theoretical envelope. My tendency is to provide the comparison data as to how the non-conventional method stacks up against conventional or accepted methods when analyzing or assessing another's work. Testing of scaled models close the gap with reality, but are not exact.
I believe that when there are deviations, it is the deviator's responsibility to provide the justification as to why the method is acceptable.
[Note: My first time task with checking a more "senior" engineer's work resulted in me marking it up and asking for technical references for those items he marked "GBI" (GBI - Good by Inspection). I even had to ask what "GBI" stood for. He basically said that I had not been there long enough to question his analysis.] We were taught in school that anyone should be able to pick up your work and understand how and why you came to your conclusion. With the exception of universally accepted formulas, I documented and referenced sources. It was easier for me to spend an extra minute, as I was working, to note the source than it was for the checker to spend hours trying to comprehend and then returning to me to ask for the source.
If you performed calculations using an accepted method, how do your numbers compare to his?
It has been a few moons since my last wind load calc involving topographic factors and I looked up the "Equal Transit Theory" for information on the nasa website (https://www1.grc.nasa.gov/beginners-guide-to-aeronautics/foilw1/#air-molecules-travel-faster-over-the-top-to-meet-molecules-moving-underneath-at-the-trailing-edge). This is what I captured. It speaks of under estimation but makes note of
- "The lift predicted by the "Equal Transit" theory is much less than the observed lift, because the velocity is too low. The actual velocity over the top of an airfoil is much faster than that predicted by the "Longer Path" theory and particles moving over the top arrive at the trailing edge before particles moving under the airfoil."
- "The difference in pressure across the airfoil produces the lift. As we have seen in Experiment #1, this part of the theory is correct. In fact, this theory is very appealing because many parts of the theory are correct. In our discussions on pressure-area integration to determine the force on a body immersed in a fluid, we mentioned that if we know the velocity, we can obtain the pressure and determine the force. The problem with the "Equal Transit" theory is that it attempts to provide us with the velocity based on a non-physical assumption as discussed above."
By the way,
thank you. I had been searching my computer folders for a 2013 presentation by Donald R. Scott, S.E. on "
Wind Loads on Non-Standard Building Configurations" for over a year. I found it due to this discussion.
James Williams P.E., M.ASCE
Principal/Owner
Yorktown, VA
