You are absolutely correct, Dilip, in noting a difference in the force fields that must be considered in water resources engineering. You have helped clarify my thinking in that regard and also in the matter of standards and codes for water resources.
In some (many?) areas of water resources engineering, we have design manuals, such as the Georgia Stormwater Manual and Corps of Engineers Manuals that provide guidelines for design processes which seem more flexible than I perceive building codes to be. For example, guidelines on the length, angle, and spacing of riverine and coastal training structures are typically non-specific, giving the designer wide latitude to fit the design to the situation.
Some countries, such as the UK, label guidelines similar to the Corps' as "British Standards," so perhaps there's less a distinction than I perceive.
ENGINEER
Columbus MS
Sent: 07-25-2025 06:07 PM
Subject: When is overdesign the correct design?
Bill – Mc, I don't think you are mistaken. As intuitively obvious as they are – there are many reasons why design processes – pose different problems depending on where they are sited. For example, river water-front, coastal water-front and in-water structural planning and designs – must be approached differently than their cousins in other areas.
Appropriate and applicable Standards and Codes are always there irrespective of where the structure is located. An engineer cannot circumvent them.
In terms of Coastal Civil Engineering (CCE) works – one needs to account for different Force Fields in a Coastal System that dictate appropriate design approaches. Further, hydrodynamic interactions with the structure – like the types of Wave Structure Interactions & Scour – must be accounted for.
Here are what have been highlighted in the Civil Engineering on our Seashore:
. . . Coastal structures are not like a tall building standing on a dry land – and they should not be treated as such. Because of their exposed location in water or at the water-front, they continuously come under attack by the dynamic and uncertain metocean forcing – from regular to extreme. They must withstand different aspects of the force fields - during construction and operational lifetime, as well as face the consequences of uncertain fluid-structure interaction processes, and have to cause minimum impacts on the surrounding environments.
Therefore the role of a coastal engineer is very crucial – not only in the establishment of design and operational conditions and criteria, but also during the process of planning, design and construction. Lack of effective coordination, cooperation and concordance among various disciplines – or perhaps in not recognizing the proper roles required of certain disciplines – could lead to earning bad reputation, and to risks of incurring serious economic losses . . .
Dilip
Dr. Dilip K Barua, Ph.D
Website Links and Profile
Sent: 07-24-2025 02:04 PM
Reading the comments reminds me that water-related design an be very different than structure-related design. It seems that water design is much less reliant on codes. Am I mistaken?
ENGINEER
Columbus MS
