Jay,
That is an incredible story and I'm sorry that it sounds like you have had to deal with issues like that so frequently in such short timespan of your career and education. I have a few brief memories of things that meet the theme of your question which I will share below, but in my opinion none of them come close to what you have experienced.
1. In grad school, I had to install temperature sensors in some local streams which meandered through my university's campus. This involved trekking through trees and underbrush to get to the water. I recall a group of students walking by and asking my partner and I if we had found a turtle and were putting it back.
2. When I was in undergrad, I was involved in a research project that involved performing energy audits on a local armory to see if we could find ways to reduce their energy consumption through more efficient lights/hvac/etc. When we arrived at the armory, a soldier on-duty there was very reluctant to let us in without military IDs, since our point of contact at the armory was not present and had not informed anyone that we were coming. He eventually let us in, but treated us with a high level of suspicion when we used the term "audit". I have since suggested that they call these projects "energy analyses" to avoid a word with such negative connotations. Nobody else at the armory wanted to answer any questions either, since according to one soldier "you guys are here to shut us down". It was ironic since we were really there to try to keep their facility open.
3. As a geotechnical engineer intern, I often performed nuclear density tests to determine soil compaction values at construction sites. If you have never seen the container that this very boring looking apparatus is transported in, it is a large yellow box about the size of a trunk, and is very clearly stamped with the symbol for radiation. Naturally, it is also pad-locked. I recall having to park a little bit away from a few construction sites I worked at, and each time I pulled this nuclear density gauge out of the trunk of my car, it was inevitable that someone passing by would either ask me "if everything was okay" or simply stare with a concerned look on their faces. I started calling it a "construction tool" and leaving it at that.
4. As a new engineer doing field work to locate certain manholes in the city of Philadelphia for the purpose of finding rim elevations, we occasionally found that the sewer manholes were located on private property. Once, we found one near what I believe was a junkyard. After spending a few minutes outside of the site, trying to find a way in, I noticed someone in a car trying to watch us without being noticed. I figured it would be better get out in front of this, and go introduce myself and explain why we were there. The people in the car were apparently "friends" of the owner of the junkyard who assumed we were trying to break in. I explained to them that if I wanted to break in, I probably wouldn't do it in broad daylight, in a bunch of bright PPE, and driving a blinking truck. The couple in the car heard me use the words "water department" and then I had to explain that no, I was not there to shut off the water, and that I only wanted to get a look at the sewer manhole in the yard. This was treated with suspicion and confusion. Eventually one of the guys suggested that he go with me to see the manhole "because if the property owner sees me with you, he might think twice before shooting you."
5. Another time in a more suburban part of the city, I was lowering a coworker into a manhole in the street to get a similar elevation value in the chamber below. A very concerned citizen of the town drove up to us and asked if everything was okay. By this point, I had learned to not try to explain the details of our task and simply said that we were "performing a routine inspection". Other times, people would come out of their houses and complain to me about things related to the water department. I would try to sympathize, and always had to explain afterwards that I did not work for the water department.
By and large, I began to ignore most bystanders and just do my job unless someone was taking particular interest in me and possibly going to get in the way. As someone who usually tries to explain things clearly and in detail, I also began giving whatever the simplest answer was, even if it wasn't entirely accurate.
I hope to see a few more anecdotes shared.
Christopher Seigel P.E., M.ASCE
Civil Engineer
