Hello Heidi,
We've experienced this recently as well. On a very basic level, Type IL is noncompliant with typical specifications used by many design firms, which have called prescriptively for Type I/II for decades. As the submittal note suggests, most major US concrete producers have switched over to exclusively IL in the last year or so. Thoroughly researched data and ASTM-sanctioned paths to approval have been available for some time (ASTM C595), but only recently has Type IL become ubiquitous in the US. It is great that a marginally lower-carbon product is replacing traditional concrete, but we do have a couple concerns about the transition:
- Research on Type IL indicates a high degree of sensitivity to particle size after grinding of the limestone.
- Many batch plants are swapping the cement in their mixes without additional testing. This is a violation of the ACI requirement that test cylinders be provided for the specific mix to be used.
- GC's are swapping Type IL in mix submittals rather than substitution requests, which is a little sneaky if the project specifications do not list IL. This conversation needs to be more transparent.
- Some data suggests possible durability issues with Type IL. Personally, I am not convinced that this is still a serious concern, but I would be worried if the producer is unaware of the issue.
I'm told that limestone production for Type IL is cheaper than Portland Cement, so regardless of the environmental impact, batch plants are saving money by phasing out Type I and Type II. With all of that said, we do live under an urgent need to reduce greenhouse gas emissions, and getting greener concrete mixes on our projects should be a priority for all structural engineers. I think engineers need to bring this up at pre-con and design assist meetings as early as possible. General Contractors need to push their suppliers to develop mix-specific test data, and understand that they've bid on a set of project specifications and have a responsibility to address supply chain and cost issues in a timely and transparent manner. As with any eleventh-hour substitution request, reviewing engineers should understand risks and benefits to the project before accepting--or outright rejecting--a switch to Type IL. In the meantime, we need to revisit our specifications post haste. Designers are already behind the curve on this.
Christian Parker P.E., M.ASCE
Structural Project Engineer
Washington DC
